Crankshaft/Crankcase
  • Crankshaft/Crankcase
    I finally got around to taking my engine to the Signature a few weeks ago for inspection. The bad news is they say the crank is cracked in two places at the oil slinger and there are holes where the engine data plate is attached to the engine (weird). So guess I'm looking for some suggestions here. Anyone know a good place to purchase a crank and fix the case?
    Re: Crankshaft/Crankcase
    Crank in a C-90 I bought was cracked in the same place, got a new 0-200 crank from G & N somewhere in KY, heard Don Swords at OSH last year, the price has doubled in 3 years, it seems continental has a service bulletin on a fix for too deep of hole, it is a often found mistake, if I have time at work tomorrow, I'll try and find that SB, Tom
      what engine do you have, I just got a C-85 crank and had it magnafluxed and it has no cracks, Tom
        Tom, I have the C-85-12. I have G & N on my list to call I think they are in Owensville, KY which is in driving distance. Hope you find that SB!
          If you're in that deep, I'd never waste my time with another C85 crank...I'd spend a couple dollars more and get an O-200 crank, etc. and go with the STC for the extra ponies!
          Just my opinion.
            Divco can repair the case as long is it isn't in more than 40 or 50 pieces.
            Are you saying the holes go through the case? The plate is secured with drive screws, so there should be blind holes there.
            New Yoke hub covers
            www.skyportservices.net
              I just found out today that there was a issue when they took the data plate off. I won't know until Thursday what they found. I spoke with DIVCO and they said it is a common problem so sounds like they have seen it. Lucky the case was not in pieces! Then again $750 to fix it seems pricy too me!
                You guys have pricked my memory.
                About 10 years ago I bought a new crankshaft from G & N for a C90 that I am working on (very slowly).
                I am pretty sure that it also fits an O-200.
                I just looked in a continental SB that listed drive train components and it showed different PN's for O-200 and C90 crankshafts.
                I am confused anybody have a good knowledge of this? I hope I have the correct crank shaft.
                But even if I don't it is a very good investment!
                  Edgcumbe G & N is the Lycoming and Continental Distributor that I buy all my engine parts from in Owensboro, KY. Here is their phone and address:
                  Edgcumbe G & N, Inc.
                  2160 Airport Road
                  Owensboro, KY 42301
                  (270) 685-2567
                  (270) 926-7547 fax
                  You may be able to find their 800 number in their ad in Trade-A-Plane , if anyone remembers what Trade-A-Plane is these days.
                  The folks at Edgcumbe G&N are good folks. You can mention me.
                  Larry Wheelock, Taylorcraft N96179, A&P, IA
                    Divco does very good work. $750 to repair/yellow tag the case sounds reasonable....they have repaired cases for sale...prices are way up. Have the accessory case and oil pump gears looked over. My last job at Divco they welded and redrilled the oil pump well. Doc
                    Doc TF #680
                    Assend Dragon Aviation
                    FAA Senior AME #20969
                    EAA TC #5453 / FA #1905
                    CAF Life Member #2782
                    "Leben ohne Reue"
                      I have an inspected and yellow tagged tapered flange for a C-85-8 if you are interested. PM me for details.
                      Rod
                        I think the 90 case has to be modified for the 0-200 crank. We had that done on the 90 in a clip wing here.
                          Rod, is the crank the same as one for the 85-12?
                            Rod,
                            Plater has the -12 taper shaft, his is not a -F engine....it DOES have the tapered crankshaft
                              The -8 and -12 both use the same crank. The original C90 crank has a slightly different oil slinger from the O-200 crank. The O-200 crank is the right part to replace the C90 crank. The case mod is trivial and Divco will probably do it as a matter of course, although it doesn't hurt to ask.
                              The case from Divco for $750 will be as good as new. I have sent cases in pieces and they work miracles.
                              New Yoke hub covers
