I have followed the various discussions regarding upgrades from Shinn wheels and brakes with mild interest. The Shinn's on My BC-12D work fairly well. They have some rust pitting on the shoes and so go through a set of brake linings fairly quickly, but that is a minor annoyance. I really haven't been seriously looking to upgrade.
In all the discussions, the argument seems to boil down to - only the Shinns are on the TC and only the Shinns fit the tapered axles. All the discussions (unless I am missing something) are about upgrading to modern Cleveland wheels and brakes. I had never imagined another option.
I was just reading the A-696 type certificate for the BC12s and got a surprise! Down on page 10 under optional equipment items 202 and 207 are the listings for the regular Shinn/Firestone wheels and brakes that we all know and love.
Searching the forum, I found a post by Robert Lees from August 2009 with a picture of the C-7000 brake shoes, but nowhere in the discussion was it mentioned that they were (possibly) used on BC12s.
Another post from December 2009 mentions getting Cleveland mechanical brakes from Univair, but given the discussions elsewhere, I assumed that this was an early field approval or something.
So it seems that the Cleveland wheels with mechanical drum brakes are on the BC12 type certificate. I understand that these wheels and brakes are also fairly dated and have their own problems, but the much wider market should at least support a few parts. Parker-Hanifin at least has drawings.
As I said above, I don't really want to upgrade my Shinns, but my curiosity has really been piqued.
Were the Clevelands ever on the BC12s as factory items?
I know about the tapered-axle problem with most conversions. The option list doesn't say anything that I can find about different gear leg assemblies. Did this Cleveland model somehow include bushings or something to work with the tapered axles?
It seems that being on the TC's approved options list one should be able to swap Shinns with the proper Clevelands. What would be involved if I happened to run into a set of the precise model number wheels and brakes off of a Pacer or a Champ and wanted to bolt them on?
Most curious, why doesn't this show up in any of the discussions of upgrades? Is this like the crazy Aunt locked in the upstairs bedroom that no one ever talks about? I would think that with all the discussion about replacing Shinns that SOMEONE would have tried this. Is there something so obvious that I am the only one missing it?
(just a second... runs over and reads the A696 TC again... There it is. Right there on page 10...) Or maybe I am misreading the part numbers or something... If I've missed something obvious, well that happens to me a lot. Let me know gently.
Skip
TF #895
N34237 BC12D-4-85 SN 7700
202. Two main wheels, 6.00-6, Type III, Firestone 604
207. Two main wheel-brake assemblies, 6.00-6, Type III Firestone Model 6C3HB
But then at the top of the section, item 201 is:207. Two main wheel-brake assemblies, 6.00-6, Type III Firestone Model 6C3HB
201. Two main wheel-brake assemblies, 6.00-6, Type III
(a) Cleveland Aircraft Products Co. Model 6.00 DHB
Wheel assembly No. C-38500HMA
Brake assembly No. C-7000
The C38500 is the drum-brake wheel used on Pacers, Tri-Pacers, Champs, Stinsons, and a bunch of others. Taylorcraft 15/20s used them as did the F19 (according to their TCs). There are a number of variations reflected in the letters after the C-38500, but they are all the relatively common drum brakes used in the late 1940s and 1950s.(a) Cleveland Aircraft Products Co. Model 6.00 DHB
Skip
TF #895
