I see that there is a 337 to install 4 tanks in the wings but requires moving a rib. Is it possible to remove the rib with most of the fabric in place on the bottom side and then cover with aluminum?
option 2 was the wing changed much when they put the big tanks in?
does the big tank have wires going through it?
If the part is no longer produced then we should be able to owner produce it right?
are their any drawings for this wing tank that could be used?
does somebody have a bad one that we could make a template from?
are the wing internals all that different than a cubs to where we could use a cubs tank?
