One Piece leading edge?
Re: One Piece leading edge?
You can put it on in one piece. Please document how you did it if you can find a way to get it on smooth and straight. I haven't tried it but have heard trying to put the LE on in one piece is a lot like wrestling with an angry python.
Anybody ever done it with good results?
I've never seen good long term results from a one piece leading edge like you're talking about. That wing flexes and moves, so eventually a problem shows up, it seems. I just keep them shorter and never have problems.
I did the one-piece leading edges a long time ago on the advice of several local geezers, (Who had never done any themselves as it turn out.)
Holy cow it was a PITA. Lots of motorcycle straps, hand shaping and special words. And it was not in conformance.
It did not look any better that the three piece, so next re-build it was back to the original method.Best Regards,
Thanks to everyone who replied. I really appreciate learning from your experience.
I'll put it on in 3 pieces. My current LE's have one piece from the butt rib to rib 5. Then another from Rib 5 to Rib 8.
Then a third piece from Rib 8 to Rib 12.
I'll plan to go back on the same way.Tim Hicks
N96872
If you notice on any original LE pieces , late 41 46 they started out screwed down from the butt out; then the holes are slotted to allow for expansion & contraction of the aluminum ( later models) ...yes they will slide a bit with heat. Very early ships had one piece , very thin ,Taylorcraft Foundation, Inc
[email protected]
