Rotating Beacon
    Re: Rotating Beacon
    Originally posted by NY86 View Post
    Check out AC43.13-2b, Chapter 4. All this stuff, including masking the light, is covered. Install one IAW this chapter. It is approved data for Taylorcraft.
    Chapter 4 covers Metal Structure, Welding & Brazing. I looked through it, but didn't see anything regarding shielding the rotating beacon. Can you give me a section or page number?
      Re: Rotating Beacon
      He said AC43.13 2b not AC43.13-1B (i used to get this messed up when i first was trying to find stuff in the AC43.13) 2b has 'common modifications' 1b is 'common repairs and construction' Hope this helps
        Re: Rotating Beacon
        Yeah, the "other" chapter 4...
        New Yoke hub covers
        www.skyportservices.net
          Re: Rotating Beacon
          Originally posted by waltermrich View Post
          What do the FAR's say about flying during civil twilight does that require a Beacon / strobe or can you fly with just position lights
          Night is defined as excluding twilight, so the night regulations do not apply.
          New Yoke hub covers
            Re: Rotating Beacon
            [QUOTE=mmartin1872;63646]He said AC43.13 2b not AC43.13-1B (i used to get this messed up when i first was trying to find stuff in the AC43.13) 2b has 'common modifications' 1b is 'common repairs and construction' Hope this helps
            THANK YOU!
              Re: Rotating Beacon
              I checked with AC 43.132b and the only mounting information I found was for aluminum skinned aircraft. I am still looking for any info on mounting a rotating beacon to a tube and fabric aircraft. Anyone?
                Re: Rotating Beacon
                I'd follow the idea for figure 4-2, and look at 'radio equipment' installation, for making it 'rigid enough' to not vibrate crazily. I believe you can't weld to the frame to put 'tabs' on to hold the 'sheetmetal' that the light would be attached to, without it being a 'major alteration' (don't quote me on that) but you could use adel clamps i bet. to hold the metal in place
                  Re: Rotating Beacon
                  Its required for the pilot to fly at night in PART 91 but not for the airplane. catch 22, gotta have it for night flying.
                  Is there some new legal requirement for a strobe in certain airspace as opposed to just navigation lights?
                  Darryl
                    Re: Rotating Beacon
                    Atlee dodge has a strobe mount for the top of the verticle or rudder. Tim
