Re: Fuselage Welding
The difference between a race car welder or industrial welder is his a$$ is not liable for the welds, as an a&p, mine is and that is why aircraft are pre and post heated in my shop.
If the part will be heat-treated after welding to achieve very high strength, a matching chemistry filler metal to the 4130 should be employed. Because of the relatively high carbon, a minimum of 200 degrees C, (400 degrees F) preheat and very slow cooling after welding should be used to avoid cracking. After welding, the part can be heated to 870 degrees C (1600 degrees F), quenched in oil or water then tempered back to say 370 degrees C (700 degrees F). A complex cycle, but this will result in a tensile strength of approximately 1380 MPa (200,000 psi). Since the weld is the same chemistry as the base material, it and the heat-affected zone will have the similar properties as the base material when heat-treated. All critical welds of this type should be inspected for internal soundness to assure they are free from cracks.
Originally posted by rail
View Post
When I was repairing some wing struts about 10-15 years ago a welding engineer whom I consulted told me I should use TIG with a pulser on them. I got a TIG at that time but could not afford the pulser. The struts came out fine. A few years after that I was able to afford this machine but I find that one can do as well without the pulser as with it, but it just takes more effort. That's what I think.
