I keep noticing that people's main tanks develop a leak in the area of the outlet.
On my tank there is a short area of normal tank bottom thickness just forward of the reinforced area around the outlet, between the outlet and the front wall of the tank. That makes a weaker area between two "stiff" parts of the structure.
Seems to me that every time the fuel-shut-off valve is opened or closed it would flex that "thinner" part of the tank.
That is exactly where the leak (crack?) is in my tank.
I'm thinking that a load spreader/transfer plate that connects (at least) to the front seam of the tank might correct the problem.
People have been fixing this problem since the 40's and I just haven't got the message yet, right? Chuckle.
Darryl
Darryl
