wing tank
    Re: wing tank
    If its listed in the TCDS as an option then yes, but if its listed as a required item then its a change to the tcds which then requires a field approval or some other data for approval. Tim
    Good point Tim.
    I assumed it was an option item but I did not read the thread carefully.
    You can't remove a required item and I was thinking of options although I did not say it.
    My bad.
      Re: wing tank
      Its a 1946 BC12-D thanks for all the info, Keith
        Re: wing tank
        I have been waiting to see TC ; & ser# ; Model # , Then I will give answer.
          Re: wing tank
          Originally posted by Larry Lyons View Post
          If it is a right tank I would be interested in it if it is usable. Larry
          Larry,
          I am sending you a PM about a wing tank.
          Buell Powell TF#476
          1941 BC12-65 NC29748
          1946 Fairchild 24 NC81330
            Re: wing tank
            to slightly hi jack the thread, I'm looking for a LH wing tank.
            TF #1030
              Re: wing tank
              Guess what, I am too. Thanks for the note guys but I got to thinking about all htat had been written and went and checked! Duh I have the RT tank already, I was just on the lookout for a LT. Sorry for the wrong lead.
              Larry
                Re: wing tank
                Fabricated wing tanks for a Clipped Wing Taylorcraft.
                  Re: wing tank
                  WOW I am in love! L
                    Re: wing tank
                    Man, don't take this wrong but.....I hate talented people. If I only had 10% of that talent. Looks nice!
                      Re: wing tank
                      Charles,
                      Nice work on the fuel Tank. Whats the capacity?
                        Re: wing tank
                        Thank you for all the compliments about my skills!
                        Tank capacity, 12 gallons.
                        Charles
                        • #27
                          Re: wing tank
                          It's only 1 bay, so it should only be around 6 gallons per side? right?:rolleyes2:
                          • #28
                            Re: wing tank
                            If the rib spacing is the same as the L-2 then I know that 10 fits. Didn't try for 12 gallons. Dick
                            TF #10
                            • #29
                              Re: wing tank
                              That is beautiful, you might get a little more capacity with the filler on the outboard side of the tank which would be just a little higher because of the dihedral, it seems like the few I've seen had lips that extended out to sit on top of the spars, but again yours are very beautiful, nice job. O. T.
