For those of you who put nutplates behind your aileron spars......how did you attach the nutplate to the spar? I see nothing useful in 43.13. Thanx.
Attaching nutplates
Re: Attaching nutplates
Mike, if you're talking of installations like this:
In my case ,Originally posted by meI am using aluminium reinforcing plates (0.080") on the new aileron spars instead of plywood.
Floating anchor nuts will be used to permit any tightening of the bolts from the front of the spars, eliminating the need for cutting a hole in the aileron fabric to get a spanner on the nut. Using floating anchor nuts will ensure correct alignment of the bolts.
The aluminium plates will be glued on, in order to eliminate the wood splitting with age around the bolt holes.
All from my website http://www.taylorcraft.org.uk/Brey_rebuild-Ailerons.htm
I used two-pack epoxy structutal adhesive.The aluminium plates will be glued on, in order to eliminate the wood splitting with age around the bolt holes.
I also drilled 1 mm (0.040") diameter holes through the plates and nail through these holes
Rob,that's such an easy sensable idea,it makes everything sooo much easier and looks sooo much better. I always hated the hinge bracket area on the ailerons simply because it's almost impossible to make the covering & paint look nice in those areas. It always drove me nuts! I really hadn't planned on recovering the ailerons on Crispy simply because they didn't receive any damage....now I bet they get recovered,you just cost me more work Rob...thanks a lot,lol.Kevin Mays
Good point Ray! I came to the same conclusion last night. There is NO room for even a thinwall socket on my center pivot bracket. Plus, how do you get to the bolt under the ball socket? That bolt can't be put in after the bracket is assembled to the spar....at least on my aileron. It is too long to slide in from the right(in Rob's pic above). Rob, how did you do it?MIKE CUSHWAY
1938 BF50 NC20407
1940 BC NC27599
TF#733
