Stringers
  • Stringers
    Tribe,
    Can someone provide some good pics of the stringers down the sides of the fuselage.....either wood or the aluminum ones? Thanks.
    Brian
    TF# 1023
    F-19 Sportsman
    Re: Stringers
    Here are some F-19 photos in which stringer attachment appears. Maybe these will help.
    Best Regards,
      Re: Stringers
      Some pictures of my BC12D
        Re: Stringers
        Norm, those are lovely!
        (Not to take anything away from Mark's, you understand!)
          Re: Stringers
          Robert, Thank you. Attached (hopefully) are dimensions and some photos of stringers that I made. I used a Sitka spruce board 2X8X14 cut into strips then shaped. I checked the attachment, looks like your going to stand on your head to see them, sorry.
          Norm
          [ATTACH][ATTACH][ATTACH]5582[/ATTACH][/ATTACH][/ATTACH]
            Re: Stringers
            That's quite a set-up you have, Norm. I'm envious, because I'd love to improve my wordworking shop to include some of that tooling.
            Wood is such a beautifully tactile material to work with, and the shavings smell so much better than metal!
              Re: Stringers
              OK, didn't find my drawing of the stringer but Norm's look just like mine. I think the top radius was either 9/16" or 1/2" (guess which one is probably easier to find).
              If you cut the wood to 2 1/4 wide by 1/2" thick you can route the curve on both ends, then run the wood through the table saw to cut out each flat to make the reduced thickness section. Once the cross section looks like a round ended barbell you just cut the strip down the middle (MAKE A JIG AND SUPER GLUE IT TO THE TABLE! You at least need a little block to support the wood down from the blade.) to make two stringers.
              Like I said, I got a nice piece of Douglas Fir that is great for this and you need to look for REALLY straight grain! If it curves off too fast the grain will run out and your stringers will be weak. I don't know if I would use white pine. Too many tiny knots and wide grain. If you can find some old damaged spars they cut up into beautiful stringers!
              If you need really nice wood look at the trim wood at the lumber yard, just stay away from finger joint and don't use Poplar! It looks BEAUTIFUL and works great, but it isn't strong enough for stringers.
              By the way, I DID find the drawings for the wood and metal "D" windows. Now I have to find the names for those who were looking for them and find out what they will cost to copy and mail.
                Re: Stringers
                I built mine out of Douglas Fir. I found a real nice straight grain one. I remember ripping down a 2"x6" and then running it through a shaper and a table saw. Twenty five years later they are still great.
                  Re: Stringers
                  Hank, I'd be interested in your drawings. Please PM me when you decide on a price.
                  N27432
                    Re: Stringers
                    Hank,
                    I too, would be interested in the window dwgs.
                    Larry Wheelock, TF671, N96179, lawheelock@earthlink.net
                      Re: Stringers
                      Hank, please add me to the list of those who would like a copy.
                      EAA 93346 TF #863
                      1946 BC-12D N96421
                      currently a collection of parts
                        Re: Stringers
                        Me too, Hank. Wood Window drawings, please.
                        Bob Gustafson
                        NC43913
                        TF#565
                          Re: Stringers
                          OK, I'm starting to figure this attachment thing out. Yesterday it took me the better part of an hour to send my pictures, only to have them upside down and sideways. For those of you that are as bad at this as I am, try this on my attachment.Open the PDF file, then view then rotate view.
                          Hank pretty much made his stringers the same way as I did it. The project of makeing stringers took most of the day to do after I had the 2X8 in hand. It takes time and patience to restore these old Tcrafts. As you all know, you will not save money restoring one of these old birds. If you want to save money , buy one ready to go. I restore these thinga because like most of you,I enjoy doing it. This 1941 BC12D airplane number 6 for me.
                          Norm G
