Plans / Drawings
  • Plans / Drawings
    Hi guys I write fron Italy,
    what I'm looking for is a set of drawings or plans for the model A to be replicated...
    It doesn't matter the format...
    Many thanks
    Re: Plans / Drawings
    e-mail us direct here at the Foudation: [email protected] , sounds like an interesting project.
    Last edited by Robert Lees; 11-15-2010, 12:03. Reason: to correct Forrest's email address
      Any update on the drawings CD for tribe members?
      Ray
        I would be interested in purchasing that CD Forrest, also a CD with the skylight drawings or info for the F-19.
        Brian
        SLC-UT
          I would like the F-19 Skylight Drawings also.
            Me too. Skylight drawings, please.
            Bob Gustafson
            NC43913
            TF#565
              George Watson may have them too. Tim
                I am in the process of restoring a 1946 BC12-D and two people said I should consider the installation of a skylight, but I am having trouble finding where I can purchase the STC or review the drawings for the installation. Any ideas where I can locate these?
                Thanks
                Richard Herzberger
                N43178 Member #1072
                Richard Herzberger
                N43178 Foundation # 1072
                  Richard, look at the tech reference section, I have a 337 there for an F-19. Tim
                    Wayne Clayton in Alaska is the holder for an STC for a taylorcraft sky light, they are a bit pricy but look up" Wayne Clayton skylight "on a forum search , Im sure you will find out more.
                      Was that a one time or multiple stc?
                        Multiple
                          His name is Gorge Clayton not Wayne He is in Alaska and you can find him on a forum search
                            From what I could find online...STC SA637AL was a one time only STC for one aircraft...a 1941 BL-65, which was built under T.C. A-700. Last reported in Tok, Ak.
                            STC SA661AL is for a BC12-D...built under T.C. A-696 (And appears to be for multiple aircraft).
                            I copied the information below from an FAA site at the highlighted link.(where you can see the PDF of the STC.)
                            Supplemental Type Certificate
                            STC Number:
                            SA661AL
                            This certificate issued to:
                            Gregory H. Clayton
                            STC Holder's Address:
                            P. O. Box 56102
                            North Pole AK 99705
                            United States
                            Description of the Type Design Change:
                            Installation of Plexiglass Skylight.
                            Application Date:
                            02/22/2008
                            Status:
                            Reissued, 02/22/2008
                            Responsible Office:
                            ACE-115N Anchorage Aircraft Certification Office Tel: (907) 271-2668
                            TC Number -- Make -- Model:
                            A-696 -- Taylorcraft 2000, LLC -- BC12-D
                            Full Text of STC:
                            SA661AL.pdf
                            The current address for Mr. Gregory, as pulled from the Fairbanks aircraft registration rolls appears to be:
                            Gregory H. Clayton
                            P. O. Box 56102
                            North Pole AK 99705-1102
                            United States
                            If anyone finds this to be faulty info...feel free to correct it or add pertinant info.
                            Dick Smith N5207M TF#159
                              That's the info I have for Greg too, Dick. Great guy...you better be ready to talk Tcraft for a little, and if you listen, you'll most likely learn a little.
