Engine Mount-Information
  • Engine Mount-Information
    I am converting a BL-65 to a BC-65. In looking for an engine mount I find that they have two types. The short and long mounts. My aircraft is a 1940
    BL-65. I need to know which mount to order. Thanks Rex
    Re: Engine Mount-Information
    Rex The long one is used on the later models with the higher gross weights. Unless your plane has been modified, you probably need the short mount.
      short unless you are installing a c-85-12 or o-200 with starter and generator
        Rex, as already mentioned, it would be a short mount for the A-65 without a starter. Also, you are not really converting the BL to a BC, your aircraft will still be registered as a BL. Only the aircraft manufacturer can change the airframe registration. You are simply installing a Continental engine.
        David and Judy
        TF# 651
        Butterfly Fun Lines
        1941 BF12-65
        N36468
        Grasshopper Fun Lines
        1988 Hatz CB-1
        N83LW
          If you use the long mount, the cowling will be different than the short mount. You will need new baffling, I used a C-150 as a starting point since I could not come up with the stamped one and trimmed to fit. If you have any questions, give a shout. Tim
            Thanks for the information, I have ordered a new shart engine mount. Have a great fly day. Rex
