cylinder question
  • cylinder question
    I found a standard cylinder that I want to have rebuilt.
    The question is "My other cylinders are +.015 can I keep this one
    at standard."
    Does a + .015 piston weight that much more that a standard piston.
    Ok everyone give me their comments before I talk to my AP.
    I hate to bore a good standard jug out .015 if I don't have to.
    Robbie
    TF#832
    N44338
    "46" BC12D
    Fond du lac WI
    Re: cylinder question
    Does this mean you don't trust your A&P???
      can't i get some comments before I ask a question to my AP/IA.
      Lostinspace need not comment
      Robbie
      TF#832
      N44338
      "46" BC12D
      Fond du lac WI
        Robbie,
        I put together several high performance engines when I was more into hot rodding. Every time I took an engine to the machine shop and told them I wanted it balanced, they asked me if I was going to use it for racing. When I told them, "no I just want it for high performance on the street", they always told me I was wasting my money. They always told me that I would never turn up enough rpms to make balancing worthwhile.
        So............... with that admonishment in mind. And considering the fact that our little engines turn about 1/3 the rpm of my high performance street engines, I would suspect that the slight difference in weight between a standard piston and one .015" over would be unnoticable. I am sure that there are pistons in the air "as we speak" that have more weight in carbon buildup on them that what little extra the oversize piston would add.
          I'll go with Richard on this one. Engines are never really balanced, as the effective weight on the throw varies as the engine rotates and the balance weight is pretty much an average. That means it is out of balance more often than in balance. Reciprocating engines are crude, frankly; but very tough.
            I installed a used engine in a T-Craft once and it had a mix of STD. and .015 cylinders. It ran just fine.
              Balancing issues aside, the standard cylinder will have a less displacement and lower compression. Significant? Maybe not, but it just sounds chinsy!
              New Yoke hub covers
              www.skyportservices.net
                Probably will work, unfortunately you will only know till after start up and if you feel any more vibration. IT might be smoother! I had a Harley with .080 over on one cylinder and it was smoother.
                  I'm not surprised!
                  New Yoke hub covers
                    I don't think an oversize cylinder will be noticeable. I am sure there are plenty of planes flying that have that configuration. As previously mentioned, there is not really that much weight difference between a standard and oversize piston. Even pistons of the same diameter have differing weights. I think these variances are less nowadays with higher tech production techniques but I agree that at the relatively low rpm it will probably be unnoticeable. And the difference in power is going to be miniscule...
                      It is bad practice to run a mixture of cylinders on an engine. Running unbalanced (out of factory tolerences) on an undampended crankshaft will create a harmonics issue even if you do not feel it. The harmonics issue when coupled with a metal prop could cause the crankshaft to fail at some undetermined point in the future.
                      I can think of all kinds of reasons not to do it, and none for it.
                        that would be true of a 6 cylinder where the throws are 60* apart. On the continental 4 cylinder they are 180* apart so the thows are at equal points of the rotation
                          This is something I worked on when balancing a small block for racing so I haven't thought about it for a long time, but----
                          I refer only to the effective mass of the piston assembly where it is attached to the throw, versus the counterbalance weight that is supposed to balance it. One varies throughout the stroke, the other doesn't. Soooo-- whatever weight you choose, it will be wrong most of the time. Angularity of throws doesn't change that, it is just piston assembly mass vs balance mass.
                            I disagree. In a flat 4 the balance "weight" is the opposing piston, which moves the in concert with the piston in question.
                            New Yoke hub covers
                              Just a thought> Since you are going to be pulling one cylinder, pull them all and weight the pistons and rods. Reassemble the engine by balancing the rods and pistons. At the very least, pull the opposing cylinder and weigh that piston and rod. If you get significant difference, then proceed as needed.
                              Tom Peters
                              1943 L2-B N616TP
