Re: Fumes In Cockpit
Looks to me like there's plenty of places for the exhaust gasses to get in the cabin. Get those fairings around the gear legs fitting better...especialy the left one..that airflow is swirling around the fuselage as well as flowing back. The gear leg openings could use some sealing up as well from the looks of it. As Pearson mentioned, the area around the bungies and aft as well as forward of them is most likely pretty open. All it takes is some time and attention to detail and thinking about where the airflow is going, and you'll get it tightened up. As John mentioned, any openings on the belly and aft fuselage are going to pull fumes in. I also agree with him in extending the exhaust stack just a bit...it shouldn't take more than an inch or so. I've had customers that complained about stuff like this and then looked at me like I was nuts when I started talking about gear fairings, boot cowl seals, etc... but when I finally got them to let me correct the stuff I told them, it worked.
JH
JH
