Bungy Chord and Tool Where Do I Get Them
  • Bungy Chord and Tool Where Do I Get Them
    I have a set that came with the plane , they are old but look unused . How
    can you tell if they are still good ?
    Also where do I ge t the cords if required and the tool to install. Actually, if
    I had a drawing for the tool I would just make it. If someone has a drawing
    please let me know so I could obtain a copy.
    Robert Bradbury
    BC12D Experimental
    C-FAJH C90
    Sen. 74X39 prop
    Seaplane 1650 Floats
    Re: Bungy Chord and Tool Where Do I Get Them
    You can order the shock cords from aircraft spruce. They stock them in the Canadian store here in Brantford, so you can just call them in Brantford instead of the 800 number. They ship Canada Post. Probably about $60.00 for the set of four and no customs hassles. Considering the effort of changing them, I wouldn't bother with old ones since rubber does degrade over time. As for the tool, there are pictures of it in the forum which you might use as a guide - just do a search.
    Aircraft Spruce Canada
    150 Avenue Aviation
    Brantford, ON N3T 5L7
    (519) 759-5017
    Andy
      David Rude sells a bungee tool. We bought one and have used it several times in past couple years. Takes us a whopping 15 minutes to swap bungees with his tool. I love it.
      His username on here is "drude" I think.
      DJ Vegh
      www.azchoppercam.com
      www.aerialsphere.com
      Mesa, AZ
        If you look on the Foundation page ;
        there is a Technical Resources link;
        Scroll down to the Bungee Tool section.
        Info is there if you chose to buy one of mine, $93 + shipping.
          150 Avenue Aviation
          (519) 759-5017
          Andy
          Thanks for the tip, I will probably just buy new . I've been out of the loop for
          a while as I didn't know A.S. had a store in Canada .
          Robert Bradbury
          BC12D Experimental
          C-FAJH C90
          Sen. 74X39 prop
            I'll just buy one of yours for that price . Is paypal ok , or what do you prefer?
            Robert Bradbury
            BC12D Experimental
            C-FAJH C90
            Sen. 74X39 prop
              Thanks, I will buy one from him. Easier and faster than doing it myself.
              Besides, I am very busy and don't have the time.
              Robert Bradbury
              BC12D Experimental
              C-FAJH C90
              Sen. 74X39 prop
                Re: Bungee Cord and Tool Where Do I Get Them
                Aircraft Spruce show Shock Cords as follows:
                9090 , 9044 , 06-00829HD , 1080
                Which one do I need, there is no discription . Also in addition to the
                this is there some kind of safety cable/stop in the event of failure of
                the bungee cords ?
                Robert Bradbury
                BC12D Experimental
                C-FAJH C90
                Sen. 74X39 prop
                  Yes on the safety cable. What model airplane do you have? Tom
                    I ordered the 9010HDX. .. .it is for F19 and F21 etc and is the heavier weight version- with your bigger engine and mods you may want to consider it. They also have a cold weather version. I have an IO-320 on my clipwing and it will weigh around 875. For my BC12-D-85 I always used 9010 HD and put an old one on too- I know it is 3 per side but it really made it alot nicer.
                    Eric Minnis
                    www.bullyaero.com
                    Clipwing Tcraft x3
                      I thought you got rid of the 320 and went back to the 0-200 ? Then again I
                      remember that from many years ago, maybe I'm thinking about someone else.
                      I'll go with the 9010HDX as you suggest as mine is on the heavier side, tho not sure exactly because I've only flown floats, never had the ship assembled
                      on wheels before. Is is two or three per side, I was told by others that I only
                      needed four. And what about the safety/stop, is that a cable or other material?
                      Thanks for the feedback
                      Robert Bradbury
                      BC12D Experimental
                      C-FAJH C90
                      Sen. 74X39 prop
                        What he was saying is 2 new and 1 old per side. 2 per side is all you need. The safety cables should be made from 5/16" cable. I looked for an old one but didn't find it, so I don't have the length for you. Tom
                          Robert: This is what the cables look like (these are for sale...$40 US + shipping. Used, but no frays). They go between the two bungees.
                            5/16" or 3/16"?
                            I though that mine were 3/16", may be reall wrong though.
                              Check is ok, will send you a PM.
