Folks - Yes, I did make a jig so that the tailpost location was set in 3D, HOWEVER....
I can make the tailpost square and centered with the lower longerons, but it's not center with the upper longerons; it's off to the right by about 1/2". I can cause the tailpost to center with both the lower and upper longerons, but then the tailpost will tilt to the left.
Any suggestions on how I can get the tailpost centered and square? - Mike
FOLO: I think I've fixed it; may have been some twist in the fuselage between the firewall and the tail
