There is a small piece of streamlined tubing welded to the top of the brake support; I believe it keeps the petals from coming too far back towards the driver. Why are they streamlined? - Mike
Why streamlined tubing on brake support?
Re: Why streamlined tubing on brake support?
I would bet the tube is the same as they made the jury struts from. Knowing how those old plants worked, and how careful they were to avoid waste, I bet you will find that the tube left over from a stick to make two jury struts is almost exactly the length to make a brake stop.
Waste not, want not. Those guys came up in the REAL depression. Not the phony one we have now.
Exactly correct, use up the scraps. Ever know that the lights for a Model T Ford were made by a company that had to ship them in a box designed by Ford taht were used to make the floor baords for the T ?? So many times , the oval is confused with streamline tube , the oval for the jury struts was round tubing that ahd been merely squeezed into the oval shape.Taylorcraft Foundation, Inc
taylorcraft@neo.rr.com
