I've got the wing tank on the back porch with a condom over the input, a plug on the output (since I couldn't find a schrader valve) and I've inflated the condom by blowing into the drain valve. The condom collapses after about :05.
I've pressurized the tank slightly, coated it with soap bubbles but am unable to locate a leak
My A&P suggests simply filling the tank with kerosene and looking for a leak, but what would I then do with 6 gallons of slightly used kero?
Any reason I can't fill the tank with water for several hours, look for drips, then drain the water out? Then slosh with kero or (as in another thread) alcohol?
What's the harm? - Mike
ops:
