Hello Fellow T-Craft Owners,
I have a bit of a problem and I would really appreciate your expertise in this field. I have a 46 BC-12-D that was upgraded with the Harer STC in 1973. The aircraft was wrecked since then. All I have for paperwork is the 337. I’m looking for the drawings, or a complete list of what is supposed to be done with this STC.
I got the engine, a C-90-12F, rebuilt and I’m ready to put things back together, but, my mechanic and I are not convinced the STC was appropriately complied with,,, from the legal standpoint. IE: The fuel vent system. I have short vent lines from all three tanks, but none of them are hooked up according to a drawing I was able to find for the STC. I’m convinced the 12” engine mount is what the drawings called for, but I don’t know that for sure either.
Also the engine, according to the 337, was adjusted and rigged to be equivalent to the C-85. What did they do? I’m pretty sure I understand the reinforcements to the wings where the lift struts attach: Larger bushings attaching to the spars, and a plate welding them together. Maybe?
I fear when it was damaged things were not repaired properly and or things left off or out… ? Partly due to the poor work preformed.
It also came with 6X850 tires with no paperwork… does anyone have a 337 so I could get mine approved?
Thanks so much,
Gallager B
STC areas of concern:
1. Engine mount- ---I know there are several mounts.
2. Engine baffles --- Does the STC have you use same baffles as the A-65 in a BC-12D? Or ?
3. Fuel lines -- LARGER fuel lines from Aux to Main? What size ?
4. Fuel line to carb. -- What size?
5. Brakes -- I believe the Model 19 must use Cleveland brakes. Does the STC require this as well.
6. Electrical System- -
7. Tires- Not part of STC ?
Thanks so much,
Gallager B
