Cleaning house again.....
  • Cleaning house again.....
    Getting rid of most our Taylorcraft parts. No struts, cowling, or gear (B gear). Most everything else available although quantity may be limited. I have one person already in line for a few items. Just a few things off the top my head:
    Lots of wing parts minus prewar ribs and cast aileron hinges
    instrument panels
    doors
    rudder pedals
    gas tanks
    instruments
    engine mounts
    brake parts limited
    exhaust
    ailerons
    stabilizers
    elevators
    tail wheels
    lots of small items
    Re: Cleaning house again.....
    Let me know what you'd want for a rudder, 2 horizontal stabs, and 2 elevators for a BC12 if you have them. The owner of the one I work on would like me to recover his, but doesn't want the down time and is willing to buy a spare set and just swap them when done. Let me know what you have and how much and I'll see if he approves.
    If you can read this, thank a teacher....
      Let me know how much for the exhaust. I may be interested.
      Twheels: which ones? Price
      Shimm Brakes pads? Price
      Instruments: which ones? Prices
      Small Items......?
      Thanks
      Ralph
        If you have a glove box door let me know.
        Craig Bailey
          I have a patern and material source for glove boxes if you can't find one. Most guys just make new ones from aluminum because the cardboard stuff is pretty lame but I made mine from the cardboard and like it. If the box gets loose and jams the controls I have seen I can crush the box and keep control (obviously done as a test on the ground using a junk box).
            Since you did not say BC12-D I assume '41 BC12 Dleuxe?
              Craig Bailey
              I have several doors, just need to see what are extra to the panels I have. The trick is handles
                Small Items......?
                Thanks
                Ralph
                I have a bunch of non-steerable stuff, some steerable
                Brake linings $40 set new with rivets
                what instruments looking for
                more small stuff than i want to list, just ask for what you are looking for
                  Something i do have is probably a dozen glove boxes for an early Bonanza. New, aluminum, flocked on inside tan. I have used them in the past, almost a perfect fit. Take $35 each
                    I would take a set of Shinn brake linings.
                    Would you have:
                    1- Mag switch? Price. I got one on Ebay or from someone and it has been just problem after problem.
                    2- A Maule TW "Model 8 a" rudder horns? how much?
                    3- Original BC12-D "late edition" casted door handles? I have the metal slot and would rather prefer to have the handles.
                    Christmas in January !
                    Thanks
                    Ralph
                      Would you have:
                      Thanks
                      Ralph
                      I don't have any A-7 switches. I have some very nice A-9 switches and the only difference is a battery position. Couple different style of faces $50 each.
                      No factory rudder horns, very hard to come by, i have a buch for other airplanes though
                      I will check on the handles, those are in short supply
                        I take a "nice" mag switch. Pictures of the different style faces ?
                        Maule "8a" rudder horns?
                        Thanks
                        Ralph
                          Do you have a left wing tank? I'd be very much interested in that.
                          Jeff
                          Jeff Lowrey
                          1946 BC-12D N44239
                            How about a fuel shut off rod with knob for bc12d? George
                              Mike,
                              Do you have a pair of the interior window frames for the sliding windows, or any of the trim pieces or handles for the plastic window pieces themselves?
                              Joel Severinghaus
                              Des Moines, Iowa
                              TF# 657
