Weld over braze?
  • Weld over braze?
    This is not aircraft related.
    I did some brazing on a tank and then later decided it would have been easier to have welded.
    I read somewhere that one should not attempt to weld over brazing.
    I assume because the brazing material melts at a lower temp than the base metal, that welding over a braze would cause the brazing material to boil away, spattering filler material.
    Is that analysis correct?
    I assume the recovery is to remelt the brazing filler and wire-brush it off???? - Mike
    Re: Weld over braze?
    At welding temperature the brazing material alloys with the weld making it weak? Have no idea what the fix is, except to get it ALL off.
      A good method for removing non-ferrous material is by sanding.
      You probably can't melt the braze off and if you use a grinder it will only fill the pores in the grindstone.
      If brazing is an acceptable option, then I would consider leaving well enough alone.
        You need to cut out the brazed area, brazing changes the metalurgy of the joint. Tim
          If you have to redo it with a weld, Tim nailed it.
            Can't do it, braze has to be completely removed.
