Re: "Engine Problems" Solved !
More head-scratching...
Bill, what type of air filter do you have? Is it possible that the cold air inlet to the carb box is becoming randomly blocked in some way? (there was a SB or AD for Brackett-style filter boxes some time ago).
When you go to carb heat (alt air) the obstruction is not there.
Can you try the next flight with the filter element removed?
You may have looked at all the above already of course.
Incidentally, I did a fuel cut-off flight yesterday; at full power and in the climb attitude the A-65 engine quit after 10-11 seconds or so. Certainly not as low as your 3 seconds, and I tried it several times.
I'm still not wholly convinced about carb ice at full throttle (albeit I acknowledge that it can happen...but it must be rare for it to happen to you over different circumstances, on different days etc). I get carb ice a lot at low-medium power settings, but never knowingly enough at full throttle to cause my engine to suffer as yours.
It sure is sounding like you have a fuel head/flow problem.
