I have just acquired newly built spars. They are beautiful, a work of art! However one spar (and one spar only) has been drilled and fitted with bushings. I had already decided some time ago to do this mod. as I thought I would have build to my own spars from scratch. Now I have this set that the previous owner has started with the bushing mod. and I want to continue. My question is what are the specs. of this modification, what are the bushings made of, etc? I know it is to increase the gross load, however I do not plan on applying for that. I just want to do it, as right now, it is much easier than it will be later after the wings are rebuilt and recovered. I believe the paper work includes welding a small plate on the wing attach fittings too. I really want to do all of these things just so if someone in the future wanted to upgrade the bird, all of the internal work is done. It will also give me a bit comfort when I am inverted pulling out of that botched barrel roll. Another words is this an STC or something else, and can I just get a copy of the paper work, do the mod. and note it in the log book and not change the gross loading, or do I have to buy the whole kit an caboodle, (certificate, whatever)? I have no plans on changing the Cont. 65 to anything else.
Thanks, Larry
Thanks, Larry
