Setting non-blind rivets
  • Setting non-blind rivets
    I only need to set about 6 rivets. Harbor freight only has the tool for setting blind rivets. A look at the Aircraft Spuce catalog shows the setting tool for 'standard' (non-blind) rivets; looks simply like two shafts pressing along the same axis.
    Anyone know how the faces of that rivet setting tool look?
    Anyone try to set a rivet using a "c" clamp? I made one unsuccessful attempt and wonder if it's the rotation of the "c" clamp bolt that's giving me trouble.
    Open to suggestions how to do this simply. - Mike
    Re: Setting non-blind rivets
    Mike:
    If you're setting universal rivets the tool for the factory head has a special concave shape and the tool for the shop head has a slight convex shape. Flush rivets, both sides are convex.
    I'd say borrow the right tools or have someone set them for you. It'd have to be a pretty solid C-clamp. Even a slight misalignment will mess it up.
    Don't waste a nickle on a tool from Harbor Freight for this purpose. They don't have one.
    New Yoke hub covers
    www.skyportservices.net
      If they are flush rivets, you can turn the assembly upside down onto a heavy flat steel plate, so the "shop" end of the rivet is sticking up, and use an arbor press, shop press, etc. to squeeze it down.
      Or, you can make a setting tool to use with a hammer.... a piece of steel tubing cut perfectly at 90 degrees and smoothed, and a steel rod that slides inside that tube. Use thick wall tube for a better footprint and press down with the tube so the head of the rivet is firmly in the countersink and the backing plate is keeping it all flush. Whack the rod with the hammer several times and you're set. Make several test pieces to see how many hammer blows it takes. If you want to get REAL fancy use clear plastic tube so you can see the rivet being squashed. See attached sketch.
        THAT's what I wanted to hear!
        I've been trying your trick with a drift for about an hour and all I get is an imitation of the North Korean president's haircut.- Mike
          Bill - could you please define a few terms.
          "head in the countersink" - no problem - I drilled a dent into my anvil the size of the round rivet head.
          "Backing plate is keeping it all flush". Where does this backing plate come in? - Mike
            Be careful about drilling that "dent"... if it is not real smooth it will mark up your rivet heads and it will be embarrassing and the whole aviation world will come knocking on your door complaining and waving the 43.13 book at you
            Go to anyone who is building an RV kit, or the local airport mechanic, and buy or borrow a small rivet set that fits into one of those hand squeezers. Find them on eBay or through ACS... it's worth the $20 or $40 to have a set. Even without the squeezer you can just drill a 3/16" hole in your steel plate (or an anvil) and make use of it.
            If you HAVE to do it the hard way, get a Dremel tool with one of the spherical metal cutters, but then you have to go in with a polisher or something to make it smooth. Lots of time versus just buying a squeezer set. The AN470 rivet head is not spherical anyway, it has a flat spot.
            The backing plate is the thick steel plate that is underneath the rivet, so when you hit the other end is squashes instead of just flying out of the pieces you are riveting. Technically this is called "back riveting" by the old aerospace guys and RV builders. It is a common and well respected way of getting it done with flush rivets.
            I have to suggest that you might just consider borrowing a real rivet gun and bucking bar from an RV builder or airplane mechanic. For the cost of a hamburger or a 6 pack of beer, they can demonstrate how to use it, show you how to drive the other 6 rivets, and you've got a skill that can be used over and over. The same skill can be brought to bear on wing rib repairs, firewall repairs, cowling repairs, cooling baffle repairs, lots of places even on a T-craft.
            Bill
              Even better yet, just find a mechanic or one of the old timers at the airport and see if they will help you. I am always having people stop by and getting me to do small projects when I am home. Tim
                Bill - I built a countersink to hold a rounded rivet head flush. I've been trying your tool and ineveitably, the shop head ends up offset from the original head.
                I think I"m keeping the rivet vertical. Any suggestions as to what to look for? - MIke
                  Mike, exactly what are you trying to rivet together? A little more info may be useful to those giving you suggestions.
                  thanks.
                    thanks.
                    You know the last rib on a wing, where the steel wing tip bow connects?
                    the last 4 inches of the steel bow were rusted away and the last two inches of the aluminum rib were coroded away. I've repaired the bow (see thread elsewhere) and removed the diseased portion of the rib trailing edge. I have bent some rib material to replace the portion I"ve removed and now need to secure (hence the talk about riveting) the new metal to the old. - MIkeH
                      Mike,
                      Fit the pieces together-one end over the other or make some splices(from old rib pieces works very well) secure the pieces together, and rivet from the side with standard AN rivets-this way you don't need to countersink.
                      Buell
                      Buell Powell TF#476
                      1941 BC12-65 NC29748
                      1946 Fairchild 24 NC81330
                        Ok, I think you are splicing an aluminum rib? First off make sure you follow the guidelines in 43.13 or some other source of approved/approvable data. For one thing, you will probably need a whole lot more than a half dozen rivets to make your repair. Not being able to visualize it in my mind I am guessing. Thankfully, I have never had that part of a T-craft open and really have no idea what it looks like
                        If you can get in there with a rivet gun and bucking bar that would probably be the best way. The second best choice would be to utilize CherryMax or CherryLock rivets. Those are blind rivets that can be pulled with a conventional "pop rivet" tool. (if it's a good strong one) These rivets are expensive and come in a variety of sizes. It is very important to use the exact length needed for good results. Is the part off the plane? ie, can you take it in your vehicle somewhere? If you can, I think that if you went to a local airport someone there could fix you up for cheap (or free) Or go in the morning with a dozen donuts I would gladly buck a few rivets for some donuts...
                          Is it a stamped rib or a built up one like the cubs have? If it is stamped, I would just use some AN470-3-3's spaces about 1/2-3/4" apart on the sides and some counter sunk rivets on the top and bottoms. Just go find a mechanic that is an old timer and he can do it in about 30 minutes. It would take me 45-an hour because I have not seen my tools in almost a year. Just think, if you are covering it and used good old fashioned pop rivets, the next time anyone saw it would be in around 30 years and I dont think that anyone would really give a crap then. There is not much stress on that rib, the rib stitching is the hardest strain or installing the martin wire....will do the most damage....unless you ground loop it
                            Mike,
                            Buell
                            That's my intent.
                            First I have to get these rivets to set properly; that's the immediate concern. - MIke
                              Correct
                              This is a skill I really want to learn. I know I can go to the nearest EAA chapter (I'm a member) and someone will do it for me, but Bill et al have suggested it can be done by hand without an expensive rivet set or hand squeezer so I want to give that a chance. - Mike
