brake master cylinder
  • brake master cylinder
    howdy all,need some info a master cylinder for heel brakes thaks marc n43643
    Re: brake master cylinder
    Use matco's they are the most affordable, they also have some good information on the Grove landing gear site about ratio needed to compress the master cylinder. Tim
      Here is how I did mine. . . . . it allowed me to run dual brakes with just 2 cylinders. Also I have no brake fluid in the cabin to make a mess.
      In the photo it is not finish welded- just tacked into position. Since this photo it has been fully welded up and tested- works like a charm and doesn't require and mods to the airframe other than the welding on the gear.
      Eric Minnis
      www.bullyaero.com
      Clipwing Tcraft x3
        One more- the tie rods were not welded in yet but you get the picture.
        Eric Minnis
        www.bullyaero.com
        Clipwing Tcraft x3
          Was that done by STC, or 337? I've been wondering about hydraulic brakes for a while.
            There is no 337 or STC required for the aircraft pictured above.....it's and experimental clipped wing t-craft
              howdy tim,how did you mount the macto cylinder and do you have any pitchers steve at steve aircraft is helping me get the stc also there a tcraft in ashland with piper j3 cylinder thanks marc n43643
                I have posted pics for people of my toe brake conversion, I was going to persue an SCT for them but right now I am focusing on my fuel valve STC first. PM me your email adress and I will email you the pics. Tim
