Re: Avgas vs Autogas
The pictures you can see here show what a steady diet of 100LL will do to a small engine after only 300 hours. As Mike stated, there is too much carbon build up using 100LL. This problem was discovered last year on our airplane. It started with a stuck valve. My dad insisted we pull a cylinder and take a look, it was not acceptable to him to just free up the valve and keep flying. Boy am I glad I listened to Dad!
Of the 4 jugs, two had stuck piston rings. You can clearly see the carbon was chipping off the pistons and scoring them. Finding this, we went further and removed the oil tank and found the carbon chips had migrated to the oil pick up screen and it was probably 30% blocked.
Keep in mind this engine had only 300 hours on it from its last top overhaul. Needless to say it got another one last year. My advice to anyone is get the mogas STC and blend 1 gallon of 100LL and 4 gallons of unleaded together and if you feel like it, 2 ounces of MMO. This will give you the correct lead content for these little engines. Also, please be inquisitive: IF you have a stuck valve, it may be tempting to just get it unstuck and keep flying, but please reconsider, there may be more going on inside your engine than you think.
. This was on a 140 with a C90 that has been on a steady diet of 100LL from a previous owner. Buildup on the valve stem/guide from the 100LL was definitely the cause.
