I recently learned that on cars, they changed the markings on the dipsticks to reflect a warm/hot reading because they knew that everyone only checked their oil after driving to the gas station.
I'm curious about what you all do when checking oil in the plane:
Do you go by the dipstick reading after the engine has been sitting (say overnight), or do you use the reading you see after you've had the engine running, (even if only for a few minutes)?
There is a few quart difference between the two readings.
I have the O-200 in the F-19.
