Re: Lust for POWER!
Thanks John
Excellent information. Is there some technical documentation to be found showing the swept-area geometries for these engines? Also, is it the 90-8 case that has the same mounts as the a-series? And what are the pros/cons between Millenium and TCM cylinder assemblies? I have a parts catalog that calls out 6.3 and 7.0 compression ratio pistons for the o-200. What is the CR with the -85 pistons on the -90/0-200 crank? Do the -85 pistons carry an oil ring on the skirt?
Jeeze, I could go on forever! Where does one find this information? When I get around to inserting tab-A into slot-B I want it to fit.
Thanks again
jCandlish
Originally posted by NY86
View Post
Thanks again
jCandlish
