Lust for POWER!
  • Lust for POWER!
    So I've found both c-90 and o-200 engines in various states of repair
    I am led to believe that the installation of c- series engines is mechanically similar to the a- series and uses the same motor mount.
    What is the situation with the o-200?
    Thanks
    jCandlish
    Re: Lust for POWER!
    John,
    Many people have put the O-200 on the BC12 and I suppose also the BC65 airframes. The nice part about using the O-200 is the readily available parts.
    Since I do not know the laws in Switzerland, I do not know what it takes to put the engine on and keep the government officials happy. I know it takes a Supplemental Type Certificate or a Field Approval in the US to do any sort of modification of that extent.
    The model F-19 Taylorcraft does indeed use the O-200 and is very popular in mountainous areas and where there are many short airfields. So I hope you do indeed put the extra power on your plane.
      Re: Lust for POWER!
      Thanks Mark
      My plane N23638, remains in November registration. I have a accommodating roving FAA-IA who is practical. The most difficult regulatory issue is the Avionics, for which I must visit the certified FAA Repair Station in Geneva.
      My question remains more mechanical. I infer from your answer that the F19 motor mount bolts up to the o-200. Are then there two different long mounts.
      Just how many motor mounts are there?
      . a-40
      . early lycoming
      . early franklin
      . a-65
      . c-85 short ???
      . c-85 long ???
      . o-200 long ???
      The correct motor mount is certainly called out on the required STC. Is there a short o-200?
      Thanks
        Re: Lust for POWER!
        If you want to know about installing an O-200 on a short mount, PM me and I will give you ALL the details. There is NO STC yet for that installation. Tim
          Re: Lust for POWER!
          If you decide to make the engine swap in the U.S., will you be willing to let the Taylorcraft owners members have first crack at your stock engine? ( it never hurts to have a spare). Brie
            Re: Lust for POWER!
            Hi Brie
            I've found 2 high time running engines over here. an o-200 and a c-85. I'm still on the lookout for a c-90.
            I'll be keeping the original engine as the serial # matches the original factory logbook.
            Stock engine? Thats funny.
            Cheers
            jCandlish
              Re: Lust for POWER!
              Buy the 85, you can bolt it to the short mount without any modifications...the 90 is great but not worth the extra wait or cost. Don's Dream Machine can get you the STC for the O-200 rotating assembly in the -85. You would get the O-200 size but in the 85 case. Its the best all around option and you can use the same motor mount rubbers as the 65 and the baffling will interchange. If you really want to fool someone, have Don's modify it to a -8 and use the O-300 intake elbows and it looks like a 65 but perfroms like a 90. Tim
                Re: Lust for POWER!
                Hi Tim
                I'll be buying with money that can only be spent once, so I'm looking to make the best informed decision. Unless someone would like to donate an engine to a good cause!?
                This is for next winter, as my airplane is flying now, or it was last week, and will be again and in annual this months end.
                I'm of the impression that there are more c-90 cores here in Europe because of the WWII liaison aircraft, and most of those seem to be rolls-royce.
                So now to the question section.
                I've heard that the most substantial difference between to c- series cases and the o-200 is the mount. Is this just rubber?
                I've also heard that the webbing strength, from weakest to strongest case is -85 -> -90 -> -200. Is this so?
                I've been lead to believe that the -85 piston has more crown, or has a deeper wrist-pin, so that it develops more compression than the -200 piston in the same bore. True/False?
                I'm lead to believe that the crank is the same between the -85, -90 and -200, and indeed the stroke is the same as the a- series. True/False?
                What cams and cam+ingition timings are available. I've heard that you can advance the cam timing gear for a performance boost, at the cost of hard starting. True/False?
                Thanks
                jCandlish
                  Re: Lust for POWER!
                  I just bought N95193 - '46 BC-12D with an A-65-8 for the powerplant. I want to add a starter to make life easier. I've got a line on an accessory case for the A-65 with the bracket for the starter. Will I be able to convert the A-65-8 to accept the accessory case and add the starter, or should I save my money? Should I look for an engine that already is adapted for the starter?
                    Re: Lust for POWER!
                    A properly adjusted carburetor and impulse coupling magnetos on an A-65 allows the engine to start on the first hand pull each and every time.
                    IMHO, putting a starter on an A-65, including the battery installation, wiring, and other modifications, would be making your life a lot more difficult. The extra weight and complexity, having to charge the battery, modifying the instrument panel, etc. also favors the simpler way.
                    I think the vast majority of people on this group will agree that we can personally guarantee you will have less hours in your logbooks and less money for avgas if you decide to put a starter on than if you decided to make your airplane hand start reliably.
                    Having your carburetor even fully overhauled is a lot less time and money than adapting the starter to your engine. Tens of thousands of T-crafts, Champs, Cubs, Porterfields, Luscombes, and many more have been starting easily and reliably for... oh, about seventy years now... without starters.
                      Re: Lust for POWER!
                      Hi Mike
                      Life may be easier without the starter. My engine almost always catches on the first hot blade. The key is to be systematic.
                      Cheers
                      jCandlish.
                        Re: Lust for POWER!
                        The problem with this engine isn't the first start, it's the next one after taxiing to the fuel pump, putting gas in, and then trying to start the engine again. It's terrible. The engine just floods, even with the fuel turned off.
                        I'm new to this airplane, so I hope after getting more time with it, perhaps I will have the same experience as you all. I'm still a little nervous about the hand starting. Don't want to get hurt, and don't want to lose all my flying buddies after they get sick of helping with a hand crank.
                        Sounds like it needs some work.
                        Thanks for the information.
                          Re: Lust for POWER!
                          Hi Mike.
                          I always shut my engine down with the fuel shut-off valve, never with the mag switch. That way every start is from a relatively empty throttle body. The imperial valve (shutoff) and float/needle assemblies will leak enough to keep the fuel bowl full.
                          You can also open the throttle and carb-heat between starts, but watch that throttle setting mags hot!
                          Cheers
                          jCandlish
                            Re: Lust for POWER!
                            Friday is my day off, so I'm looking forward to going out to the airport and playing with my new toy.
                            I will heed your advice and see if it helps.
                            I'm just looking forward to having fun flying in the T-craft. It is such a pleasure to fly it.
                              Re: Lust for POWER!
                              The mounts on the O200 (and C90-14) line up with the A- and C- series but they are thicker fore and aft. An O200 will sit about 1/2" farther forward. Don Swords has an STC'd bushing to convert it to the conical mounts that corrects this.
                              There are 2 basic cases, pre-O200 and post O200. Pre-O200 cases have studs on the center main bearing. Post-O200 cases use through bolts and are a lot stronger, especially if you make a habit of hitting hard objects with your metal prop. The studs will rip chunks of the main bearing saddle loose.
                              You need the answer to the next question first.
                              False. The A-series and C75 and C85 share one crank and one stroke. The C-90 and O200 share a different crank and longer stroke.
                              If you put C85 pistons on a C90 crank and rods the compression ratio goes [way] up because there is more piston above the wrist pin. With the C85 crank the compression is less because the piston top comes to the same point in the bore [as the C90] but the stroke is shorter.
                              You're on your own here, AFAIK.
                              New Yoke hub covers
                              www.skyportservices.net
