strut attachment AD - failed
    Re: strut attachment AD - failed
    I have a 337 for a previously done repair and attached to it is a template for cutting out a patch from 4130 plate.
    Could send you a copy if it helps.
      thanks Dave. do you have it in electronic format? .pdf maybe?
      Also, can someone tell me how these fittings are attached to the plane? welded? or what? how would one replace the fitting?
      DJ Vegh
      www.azchoppercam.com
      www.aerialsphere.com
      Mesa, AZ
        Since Maule makes ceconite covered planes I would think this tool works on ceconite.
        Also the instructions make no mention of using it on any particular fabric it just says fabric.
        I also suspect that the type of fabric makes no difference.
        Looks to me like it is simply applying force on a known shape against a thin sheet as a means of estimating the sheet's ability to withstand tension so it's function is pretty independent of the fabric type.
        I am sending mine in for calibration and will ask about this subject at that time.
          Will have to copy and send or FAX to you.
          They are welded on, but the 337 I will send does not replace it per se. It wraps a new piece arround it and welds the new piece to the old one and the fuselage.
          So you end up with new fitting wrapped over top of the old one.
            Originally posted by jdoran View Post
            DJ,
            I am a seaplane operating from brackish water.
            Over the years, the bracket and surrounding areas had been painted, painted, painted, sprayed with goop, all in an effort to protect the area from corrosion. There was so much stuff, you really couldn't inspect the area to comply with the SB.
            We cut away the fabric and sandblasted the area to bare metal using an inexpensive blaster hooked to a small shop (Sears) compressor. The sand gets into ALL the nooks and crannies.
            I guess I'm glad the AD forced me and the A+P to really clean up and check this area out. We had the area x-rayed as well just for peace of mind.
            This is an inexpensive way to clean your bracket area and have the welding repair done without spending a fortune to completely rebuild the plane.
            I have done that also maybe 20 years ago and afterwards the grit from blast ruined the cables at the fairleads. Might want to take a look just in case.
              My understanding is that the "Maule" tester is the unofficial name for the Betts tester ("Bettsometer") (named after the designer) and that the results have no standing for certified aeroplanes, since it was designed for uncertified ultralights.
              But I am willing to be corrected.
                You are exactly correct. Maule states that too. ie that it is unofficial (it is pre -ultralight so must not be a bettsometer)
                But it better than a thumb, pencil... or nothing
                Its merely a guide
                  Looks like I was wrong about this part in red.
                  Here is the paragraph from AC43.13-1b
                  2-34. FABRIC TESTING. Mechanical devices
                  used to test fabric by pressing against or
                  piercing the finished fabric are not FAA approved
                  and are used at the discretion of the
                  mechanic to base an opinion on the general
                  fabric condition. Punch test accuracy will depend
                  on the individual device calibration, total
                  coating thickness, brittleness, and types of
                  coatings and fabric. Mechanical devices are
                  not applicable to glass fiber fabric that will
                  easily shear and indicate a very low reading
                  regardless of the true breaking strength. If the
                  fabric tests in the lower breaking strength
                  range with the mechanical punch tester or if
                  the overall fabric cover conditions are poor,
                  then more accurate field tests may be made.
                  Cut a 1-1/4-inch wide by 4-inch long sample
                  from a top exposed surface, remove all coatings
                  and ravel the edges to a 1-inch width.
                  Clamp each end between suitable clamps with
                  one clamp anchored to a support structure
                  while a load is applied (see table 2-1) by adding
                  sand in a suitable container suspended a
                  few inches above the floor. If the breaking
                  strength is still in question, a sample should be
                  sent to a qualified testing laboratory and
                  breaking strength tests made in accordance
                  with American Society of Testing Materials
                  (ASTM) publication D5035.
                    Before you repair your strut fitting, compare the cost difference between that and installing new fittings. Then compare what the little guy on your shoulder is going to be whispering in your ear the next time you take off in that airplane.
                    I suspect that with a brand new fitting installed by a fully competent welder, the little guy on your shoulder is going to be whispering something like, "You are a safe pilot, you are a tribute to general aviation, I bet your wife is glad you erred on the safe side".
                    After even the very best repair I suspect the little guy on your shoulder will be whispering something like, "Gee, I hope that repair is as strong as a new fitting, that weld looked pretty good....didn't it?, so what if the repair fails-you saved almost a grand.
                    There is nothing like peace of mind for an enjoyable flight!
                      papi kak
                        The little guy on your shoulder needs to ask the question "does Taylorcraft have this fitting in stock, is it newly manufactured parts or was it a 40 year old fitting sitting in a rusty pile that they just threw a coat of paint on, etc."
                        The little guy on your OTHER shoulder needs to make sure the part is shipped COD.
                        If a new fitting from Taylorcraft would make you sleep better, by all means put them on.
                        IMHO it depends on how much of the original fitting was corroded and how badly.
                        • #27
                          A patch over the fitting like Swick used would make me feel a whole bunch better the just replacing the stock fittings. Tom
                          • #28
                            Originally posted by Buell Powell View Post
                            DJ,
                            I can see how the crack might be caused if someone wasn't careful when installing the struts ...
                            Buell,
                            Sorry to comment on this after five days but the older I am, the behinder I get!
                            This is at least the second time that I have seen a comment similar to this one on this forum. I think the last one was something like, "more damage could be done to the fittings while removing and installing the struts..."
                            I hope to have the money to get all this done to my Taylorcraft in the Fall, but my mechanic will only sign off my work and now I am concerned that I might not know what I'm doing if I could easily and unknowingly damage my strut fittings. What do you mean by your comment? Any comments at all are welcome.
                            Jack Dernorsek
                            N44057
                            '46 BC12D
                            • #29
                              Originally posted by hangarb7 View Post
                              Buell,
                              Jack Dernorsek
                              N44057
                              '46 BC12D
                              The attach fitting has 2 slots for the struts to be inserted. If the struts are moved fore and aft while installing or removing it can damage the fitting. Tom
                              • #30
                                Can you be just a little more descriptive? How much force are we talking about in movement? Ounces? I'm really concerned now. Can that happen immediately once the fastener is removed?
                                What if, heaven forbid, the replacement strut assembly doesn't fit perfectly and needs encouragement to be fitted into the slots? That sounds like real damage there.
                                Thank you for all replies,
                                Jack Dernorsek
