My plan is to do the minimum needed to get this beast in the air. I'd like to remove all the fabric on the wings and the green glue, and then let an inspector tell me what I need to fix.
Removing the tank will require removing steel rods which go thru it. Any reason I can't simply use a condom to check for leaks and let it go at that? - MIke
