This means that my Clip wing Swick T that I have worked on for the last 15
years will be turned down also. There are 1000's of airplanes across the
country that are JUNK now.
David Goad
----- Original Message -----
To:
Cc:;
Sent: Thursday, February 21, 2008 1:18 PM
Subject: Amateur-Built Aircraft Certification Requirements
> Dear Mr. Goad:
> This message is to inform you of changes to Federal Aviation
> Administration (FAA) procedures concerning certification of
> Amateur-Built Aircraft. Change 3, to FAA Order 8130.2F, Airworthiness
> Certification of Aircraft and Related Products, was released on April
> 18, 2007. The change includes clarification of certification
> requirements for amateur-built aircraft and affects your ability to
> obtain an amateur-built aircraft airworthiness certificate for your
> type-certificated Taylorcraft airplane.
> Section 9, paragraph 146 of Order 8130.2F, now contains a note that
> states “A rebuilt, altered, or repaired type-certificated aircraft DOES
> NOT meet the intent of § 21.191(g) and DOES NOT meet the § 21.191(g)
> requirement that the major portion of the aircraft be fabricated and
> assembled.”
> It has never been the intent of either the regulations or FAA policy to
> allow the conversion of a type-certificated aircraft into an
> amateur-built aircraft. The intent of the regulation and policy can be
> tracked back as early as October 1952 in which the Civil Aeronautics
> Administration (predecessor of the FAA) published Civil Aeronautics
> Manual 1, which provided an interpretation of the amateur-built aircraft
> rule. The interpretation of Civil Air Regulation, part 1.74.3,
> Certification of Amateur-Built Aircraft, stated in part “…Structural
> components of other aircraft may be used; however, it is not intended
> that this provision be used to avoid obtaining approval of major
> alterations to aircraft previously certificated in another category…”
> Your aircraft may, however, be eligible for an airworthiness certificate
> in the experimental category for the purpose of exhibition under 14 CFR
> § 21.191(d). Valid exhibition purposes include organized air shows,
> fly-ins, youth education events, static displays, aerobatic competition,
> movie or television productions, etc. The aircraft’s eligibility for
> that certification would have to be determined by the local
> Manufacturing Inspection District Office (MIDO).
> If you have any questions concerning current FAA regulations or policy,
> please feel free to contact me.
> Sincerely,
> Ford J Lauer III
> Manager,
> San Antonio, Texas
> Phone: (210) 308-3360
David Goad
To:
Cc:
> Dear Mr. Goad:
> assembled.”
> Sincerely,
> Ford J Lauer III
> Manager,
> San Antonio, Texas
