With full power, my A-65-8 will get a max of 1950 rpm. The TCDS says not under 2070. I had the prop repitched with no change. Both mag drops are equal at 20 rpm -- the carb heat works ok. What are some other causes to have checked? Thanks all..
Static RPM too low
Re: Static RPM too low
remember the quick tach check , after dark, place the ship with the back toward a light, run the engine up and at 1800 RPM the blades will appear tostop. 60 cycle / sec you know!Taylorcraft Foundation, Inc
[email protected]
Timing and compression check too.Taylorcraft Foundation, Inc
[email protected]
