Static RPM too low
  • Static RPM too low
    With full power, my A-65-8 will get a max of 1950 rpm. The TCDS says not under 2070. I had the prop repitched with no change. Both mag drops are equal at 20 rpm -- the carb heat works ok. What are some other causes to have checked? Thanks all..
    Dan Brown
    1940 BC-65 N26625
    TF #779
    Annapolis, MD
    Re: Static RPM too low
    Tachometer?
      try using an optical tachometer
      also make sure you have fresh fuel
        Mixture or mag timing, or a little of both. IF the tach is accurate.
          remember the quick tach check , after dark, place the ship with the back toward a light, run the engine up and at 1800 RPM the blades will appear tostop. 60 cycle / sec you know!
          taylorcraft@neo.rr.com
            Thanks all. The tach checks OK -- will look at mixture and mag next..
            Dan Brown
            1940 BC-65 N26625
            TF #779
            Annapolis, MD
              Timing and compression check too.
                Must be a gas discharge lite like a mercury vapor or flourescent. Worked good for me at 1800 rpm.
