Shinn Brakes Conundrum
  • Shinn Brakes Conundrum
    Bear with me, guys. I shipped the Shinn brake shoes and "I" shaped retainers for the shoes off to the powder coater. One "I" piece was marked "R" and the other was not stamped, so I assumed it to be the "L". Now they're back, ready to assemble, and I find nothing is as it should be. The piece marked "R" only fits my NOS aluminum dust/backer plate which is clearly stamped "Left". The unmarked piece also only fits the "Left" marked backer plate. Assumptions: the "I" piece is incorrectly stamped with an "R", both the left and right NOS dust/backer plates are stamped incorrectly, I have two of the same side "I" pieces, a genie jumped into the parts box sometime in the last 30 years and swapped parts with someone else. I can see that there really needs to be a Left and a Right brake set-up because of the off-set actuator half-loop, the eccentric backer plate locater pin and the off-set adjuster sliders/nuts, but I do not know why or how to determine which is which. Any one out there got a quick check for me to see what happened here? Also - it appears I'll need to swap my newly powder coated "I" piece, which may be an "R", for someone's extra "L" piece. Any one have a serviceable one to trade for a beautiful black powder coated one? Clear enough? Sorry for being a rookie about this, and thanks for any help! Bob Coolbaugh
    Re: Shinn Brakes Conundrum
    My parts blow up shows only one part number for the "I" piece (6CA27NA)
      dust covers show p/n as 6CA3 and 6CA4 I assume that means Left and Right
        Hi Bob,
        These are off my L-Bird.
        Marked "L" and "R" near the boss. (they are also marked on the opposite side)
        Note the different notch locations for left and right.
        Jim
          Thanks, Gents.
          Jim's thumbnails showed exactly what I need to see. That means I have 2 of the same side "I" pieces. Now - the replacement parts search begins! Any one have a spare "I" piece or a parts source for one? I can trade my perfect, powder coated extra for whatever you have or purchase it outright.
          While we're on the subject - has anyone found a source for the 1/8" thick by 1" wide brake lining material? I have only located 3/16" wide stock, which appears too thick to fit without turning down. If I want to buy 50 foot min. rolls, I can get exactly what I need - but that's enough to do all the Shinn brakes out there for the rest of our flying! Just need 3 feet m-o-l. Bob
            These guys have linings and other parts
            SkyBound, Atlanta Georgia
            Shinn Wheels, brakes, cables, backing plates.
            Jim Greene (owner) 770-446-6797
            I am perplexed about the parts book showing only one p/n since the pictures show a clear difference. I must be missing a note that says add L or R to the p/n
              Originally posted by NC22211 View Post
              Thanks, Gents.
              Bob, email me. I have plenty of support plates and have lining material.
