W&B problem
    Re: W&B problem
    DJ, see red text, this is a paste from the TCDS but I lost the formating so you may want to look for that text in the actual TCDS, I suspect your IA knows this. The oil not being counted isn't commonly known, nonetheless it is true
    IV - Model BC12-D, 2 PCLM, Approved November 23, 1945; Model BCS-12D, 2 PCSM, Approved February 19, 1946
    (Same as Model BC12-65 except for alternate tail surface, revised aileron travel, alternate one piece windshield and other
    miscellaneous structural and non-structural changes). (Model BC12-D1 eligible as Model BC12-D when items 601 and 204
    and 6 gal. right-hand wing tank are installed).
    Engine Continental A-65-8 (see item 114(d) for optional engines)
    Fuel 73 min. grade aviation gasoline
    Engine Limits For all operations, 2300 r.p.m. (65 hp.)
    Propeller Limits Static r.p.m. at full throttle: not over 2250, not under 2070.
    No additional tolerance permitted.
    Diameter: not over 72 in., not under 70 in.
    Airspeed Limits Landplane: Level flight or climb 105 m.p.h.
    (True Indicated) Glide or dive 140 m.p.h.
    Seaplane: Level flight or climb 95 m.p.h.
    Glide or dive 129 m.p.h.
    Center of Gravity (C.G. Range) Landplane: (+14.2) to (+20.0)
    Seaplane: (+14.2) to (+20.0) with Edo floats (item 205)
    (+14.6) to (+20.0) with Heath floats (item 211)
    Empty Weight C.G. Range Landplane: (+14.8) to (+17.9)
    Seaplane: (+14.8) to (+18.3) with Edo floats (item 205)
    (+15.2) to (+18.3) with Heath floats (item 211)
    When empty weight C.G. falls within pertinent range, computation of critical fore and aftC.G. positions is unnecessary. Ranges are not valid for non-standard arrangements.
    Maximum Weight Landplane: 1200 lb.
    Seaplane: 1278 lb.
    Number of Seats 2 (+23)
    Maximum Baggage Landplane: 50 lb. (+40)
    Seaplane: 30 lb. (+40)
    Fuel Capacity 18 gal. (12 gal. fuselage tank at (-9) and 6 gal. wing tank at (+24). See NOTE 3.
    Oil Capacity 4 qt. (-21)
    Control Surface Movements Elevators Up 27o Down 25o
    Elevator tab Up 25° Down 30°
    Ailerons Up 23° Down 23°
    Rudders Right 26o Left 26o
    Serial No. Eligible 6402 and up
    Required Equipment Landplane: 1, 2, 3, 4, or *8; 104, 108, 202, 203, 210(a), 401
    Seaplane: 1, 3, 4 or *8; 104, 108, 205, 401
      Re: W&B problem
      Hey guys, do a search of the forums and find the link to Rob Lees website for a W&B spreadsheet. Interesting discussion in that thread also.
      The main idea is just respect the gross weight limits and go fly! (;f
      David and Judy
      TF# 651
      Butterfly Fun Lines
      1941 BF12-65
      N36468
      Grasshopper Fun Lines
      1988 Hatz CB-1
      N83LW
        Re: W&B problem
        when you add, remove or change a tail wheel you need to know the arm to the tail wheel's center of gravity and the TCDS gives you that as 193"
        when you weigh the airplane you need to know the arm to the point where the weight is being applied which will be at the wheel's center and the corresponds to the axle.
        for a tail wheel assembly the cg location of the tail wheel assembly and the axle loaction are not the same but for a main wheel they are since the main wheel is symmetrical
        hope that makes sense to you and helps
          Re: W&B problem
          ok.. so looks like after doing a loading schedule I'll still be able to carry full fuel in the fuse tank, myself and a 95lb passenger and still be within maximum flying CG.
          Would be over gross by about 100lb with a 190lb passenger and be .2" aft of CG. at full fuel in tank.... bummer.
          Thanks for the help... I was beginning to fear worse.
          DJ Vegh
          www.azchoppercam.com
          www.aerialsphere.com
          Mesa, AZ
            Re: W&B problem
            DJ,
            a few thoughts that might apply IF moving the cg ahead has any value to you
            put on a metal prop to add about 11 lbs at the nose
            get a lighter tail wheel
            sounds like you really don't need this but figured I'd mention it just in case
              Re: W&B problem
              I have a McCauley 1B90 metal prop (which was a pain to get certified to use on a Tcraft)
              My tailwheel is a Matco full swivel and weighs about 4 ounces more than the Scott that was on there
              DJ Vegh
              Mesa, AZ
                Re: W&B problem
                It almost sounds like your fuslage has been poorly spliced or you and your crazy IA need to work on your math,measurments,or something.LOL ,When you get the annual done you will have the most expensive "stock" BC12D on the planet.
                  Re: W&B problem
                  glad this worked out sort of quickly and easy for you
                  I recall in '82 when I went thru this with mine
                  I sat down on the ground one day and just wanted to crawl into a hole and dissappear I was so discouraged and beaten
                  just wanted to cry, and a grown man with a family!
                    Re: W&B problem
                    DJ,
                    There are those who claim the aircraft will not fly unless the paperwork is in order, then again, there are those of us who know the T-craft will fly at 100 lbs. over gross, just factor in a little for the density altitude...
                    Pay the bill and get that airplane away from that anal mechanic and move on to have some fun, we are rooting for ya! :beerchug:
                    David and Judy
                    TF# 651
                    Butterfly Fun Lines
                    1941 BF12-65
                    N36468
                    1988 Hatz CB-1
                    N83LW
                      Re: W&B problem
                      MEASURE the arms, the tail weigh point was originally the tail SKID , not the tail wheel axle. the arm is different than the TDS OR you can put the rear scale at the 193" point.
                      I measure all arms on many ships , we do a lot of experimential ships too. Don't subtract , just drain fuel & oil and blow as much dirt out as you can.
                        Re: W&B problem
                        Forrest,
                        Why?
                        Subtracting should be fine.
                        edit; please answer but after a few minutes I think I know what you are going to say now
                          Re: W&B problem
                          not a tcraft w&b story but it is w&b.
                          When my dad was preparing to purchase a tri-pacer in 1974 he went to a guy he worked with to ask about them in detail one day. one of his questions was about gross weights and balance ,his reply was as follows:I put my wife in the plane and load it till the tail drops to the ground and when I get in the plane it is in balance,if I balance it that way I can't overload it.
                          still amuses me but we never did try it.
                          he made something of an f-81 out of 2 tripacers and carried friends to mexico on scuba diving trips and landed on the beach with it.
                          • #28
                            Re: W&B problem
                            DJ:
                            On the figures you give, I get your empty (but including oil) weight as 828 lbs at 18.98" (outside the limit).
                            I would suggest your tailwheel dimension is wrong...dimensions on our fleet here are 198", 198.5", 197" . Your 67 lb is heavy...have you got lots of paint on the tailfeathers?
                            Here is the spreadsheet I use, just change US Gal to Imperial Gal if referring to fuel.
                            • #29
                              Re: W&B problem
                              DJ I would run your IA off and go flying. If something happens use your paper work to start the fire. Looks like he wants to get the bill high enough that you'll just give him the airplane.
                              Big Daddy
                              Dennis Keels Foundation #400
                              • #30
                                Re: W&B problem
                                How did this IA from hell not notice the Matco is not TSO'd !!!
                                Last time I'm gonna suggest this, dude, I'm running out of analogies... tell the IA to step away from the Vaseline , and per FAR's he needs to give you a list of the discrepancies and sign off on HIS part of the annual!
