I know that this is around and I need some help finding it bc12d want to up grade pedels brakes and wheels to the clevland set up , can any one get me going in the right direction
Looking For Stc Cleveland Wheels And Brakes (merged)
Re: Looking For Stc Cleve Wheels And Brakes
I have Cleveland Model B-1 mechanical brakes on my BC-12D Univair had parts last time I visited with them, same brake as used on the F-19 ETCOriginally posted by harpo View PostI know that this is around and I need some help finding it bc12d want to up grade pedels brakes and wheels to the clevland set up , can any one get me going in the right direction
JS
Tim thanks here it is [email protected] , no stc , i thought there was ??? first time im green to all this paper work !!!
Harpo,Originally posted by harpo View PostI know that this is around and I need some help finding it bc12d want to up grade pedels brakes and wheels to the clevland set up , can any one get me going in the right direction
I have been trying to find a practical way to upgrade an F19 to hyd. brakes -STC would be best. If we can find enough interest prehaps we can convince Univair/Wag Aero/ Alaska Airframes to come up with one. I think it would be possible to make a kit for the strait axle and a conversion kit to the tapered axles so one kit would could be used for both. Donno but seems possible to me.Buell Powell TF#476
1941 BC12-65 NC29748
1946 Fairchild 24 NC81330
I have tapered to strt axles that came with my project pedals were installed nice clean deal , wanted and thought there was a conversion I have a stc #sa4797nm holder is E. A. Bigby need to know how to get it
Re: STC # SA4797NM how do I get it ?
the FAA registry lists the seattle FAA office number, you can contact them for more info. If you are not able to get ahold of the holder, request the info under the freedom of information act...just a thought. TimN29787
Harpo, following are several forum entries from the past on this topic. I searched the word "hydraulic" using the search feature.
STC Number:
SA4797NM
This certificate issued to:
Bigby E A
STC Holder's Address:
Rt 1, Box 612
Klamath Falls OR 97603
United States
Description of the Type Design Change:
Installation of Cessna rudder pedals, master cylinders, and axles, aircraft spruce and specialty wheel fairings, and Cleveland brakes and wheels.
Application Date:
Status:
Issued, 03/22/1990
Responsible Office:
ANM-100S Seattle Aircraft Certification Office Tel: (425) 917-6400
TC Number -- Make -- Model:
A-696 -- Booth, Lee F. dba Taylorcraft Aerospace -- BC12-D
02-11-2004
jdlawson
Registered Forum User Join Date: Nov 2003
Master Stormman,
I talked to Mr. Bigby a couple of years ago about his STC and he said it was a 1 shot STC and couldn't be used on other aircraft beyond the one he did. However, it may leave open the ability to use your aircraft & experience over the last 20+ years and ?? hours with the modification as a basis for a field approval. Any chance of getting pictures and/or a sketch of your setup?
JD Lawson
TF #206
Years ago, I talked to one of the relatives of the STC holder, via phone, and was informed that the holder was deceased. DickLast edited by Dick Smith; 12-13-2007, 11:28.Dick Smith N5207M TF#159
Dick thanks for the input , sounds like a field approval going to run it by my AI ,others have done this , so im going to have to work around this issue ,no big deal ,another brick in the wall !!! to bad that these old stc,s die away shur would be nice if they lived on as long as the old planes lived on Thanks for your input , I thank everyone HARPO !!!!
My plane had the Cessna rudder pedals and brakes put on years ago before I bought it, it was on a field approval one time only. It is getting some work done right now but when I go down to check on things in a couple of weeks I could take some pics if that would help. My gut feel is the disc brakes can put you on your nose if you don't watch out and get a little heavy on them.
