Re: in need of fuselage fuel tank
There is a fuselage tank on ebay under taylor craft not taylorcraft.
yes they are on list for Tues calls or maybe even Monday. My BC12D is in the shop for Annual , struts off Monday and then off for NDT, will report findings on the other thread. I too agree that we have certain needs and communication does work, but I am so tired of repeating the same old stuff.
I asked about landing gear without too much success.Prehaps when Forrest calls then he would have a better idea of demand and have better luck. Tom did say that since they are an approved repair station they can repair them so may be that will help.Originally posted by astjp2 View PostLanding GEAR!Last edited by Buell Powell; 01-13-2008, 08:00.
I saw that Wag-Aero got a complete list two years ago. Then I sent them a full set of tail surfaces , two hinge & three hinge. Then wing tanks & and perhaps a main fuel tank , I have all that here for them to use if they want to recontact me. I will call them again next Monday. thanks Buell all this parts stuff with Wag-Aero is history ; my drawings here at the Foundation are to be used for research, and repair by the Foundation members only, perhaps that was the problem.
D.J.
Glad things worked out OK on the fuel tank-hope that old valve worked also. Tom(@ Wag Aero) is interested in making other parts for Taylorcrafts too. I mentioned to him that I would try to find out what is most in demand so if anyone wants to let me know I would be glad to relay it to him or just give him a call. The last time I talked to Tom he is still needing a lower windshield fairing for a pattern so if anyone has one he can make those too. Hope you get your plane flying soon-bet it will be a really well maintained T/craft.
Buell
I got my tank today!
Ordered the first one off the Wag Aero line! All aluminum and quite nice.
This was the last piece to my annual puzzle and if all goes well I should be flying by the end of next week!
It's been a long 3 1/2 months and many dollars spent!
Looks like I have one on the way from Mike Redpath. He found an aluminum tank that he says is good.
As for the order placed with Harry at the factory? let's just say it's a good thing a credit card was used and not a check.
3 weeks ago Harry says "yep! I have tanks on the shelf ready to ship" Then end of last week when he was queried on where the tracking number for our tank shipment is he reply was that he was waiting from the FAA for certification paperwork to sell the tanks because the material that was used was uncertified. WTF is that all about?
Having now had to deal with Harry I feel qualified to say I think he is a complete jacka$$
D.J.Originally posted by N74DV View Postwell... order was placed at the factory for a new fuselage tank. Harry told my IA that he had some "on the shelf and in stock"
I warned my IA that this has been said before by the factory but order one up anyway and ask for a tracking number the next day. That was over a week ago. No tracking number no nothing. My IA says he called the factory and was told they'd have to "dig up the number" and get back to him.
As of now the fuel tank is the only thing stopping the annual from being completed.
I looked at my old tank and I gotta say it looks like a super easy repair. Just cut out the old pipe bung and weld in a new one. The tank appears to be in good shape otherwise.
So I either need a tank from somewhere or a shop that can repair mine and give it a yellow tag.
anyone? help?
I talked to Tom O'neill @ Wag Aero this morning. They have the PMA for building the fuselage tanks both with the gauge and vent(for F19's) and without. They have one tank completly built and 3 more that are built but are working on a better way to form the dent that clears the tubing. They expect to be able to ship them very soon. He is EXPECTING the price to be somewhere between 450.00 and 500.00. He is also expecting to be producing steps in the near future. If you want to call Tom-his extension is 124.
Hope this helps.
By the way Tom is also going to produce the bottom fairing for the windshield. He has the blueprint but would like to have an original for a pattern so if someone has one they can spare-if they will send it to Tom he will be able to produce those also.
Buell
The "steel" ones are called "terneplate" I imagine either can be done under the watchful eye of an A&P at the radiator shop. OR sometimes replace the complete bottom up the sides a few inches. OR a large heavy round patch on the bottom. Part of the problem has been the fuel shut off working the metal abck and forth. I NEVER just pull Fuel Shut Off ; unless on fire! I reach under to the lever and ease it back seeing that it does not try to twist. bye the way Barber Aircraft has a few of the Taylorcraft handles for under the tank with the correct index and little stubs sticking out.
Guest repliedRe: in need of fuselage fuel tank
Is it steel or aluminum?Originally posted by N74DV View Postwell... order was placed at the factory for a new fuselage tank. Harry told my IA that he had some "on the shelf and in stock"
anyone? help?
Go down to your local Radiator shop, they can solder in a new bung and put in a fine coat of paint and tell your IA that you found a used one that was serviceable. But I never told you that(;f
anyone? help?
DJ, I know you are aware of the problems with Harry, but I thought I'd throw some information out there for you. A good friend of mine ordered a wing tank for an F-21B back in 2003. Harry said he had them available. Long story short, it took him several months to get anything from Harry, and what he eventually got was a used tank likely stolen from someone's aircraft that Harry was "repairing".Originally posted by N74DV View PostHarry says he has tanks on the shelf at the factory. So... My IA is going to order one. I told him do it COD or via credit card and expect it to be weeks or months before we see it.
But if Harry does in fact have them in stock then we may get one as early as next week. Apparently mine is cracked at the threads and the IA says he can't fix it. I said whatever.... I would have thought you could weld in a new pipe bung.
Anyway, I hope this isn't the case for you and that your tank arrives soon and in great condition. But if Harry starts yanking your chain, I wouldn't let him drag you along very long at all before getting your money back (hopefully from a credit card) and looking for another source.
BTW, if you are ever in the Oklahoma City area, the offer to take a ride in my Pietenpol is always on the table.
Craig Helm says his problems with the factory began in October 2003 when he tried to get replacement fuel tanks for his aircraft. When he contacted the factory, Ingram told him replacement tanks would be ready in 10 days.
"Ten days came and went with no tanks," said the Graham, Texas resident. "So Steve Pierce, my mechanic, and I asked Harry if he could build us a tank to our specifications as an owner-produced part. He agreed and said we'd have the tank within a week. That week came and went."
Ingram blamed the delays on paperwork issues with the FAA, Helm said.
"He told us the tanks were done except for the FAA approval. Then Steve contacted someone at the factory, who let it slip that they were not even working on the fuel tanks and that nothing had been submitted to the FAA," he said. "We were told the fuel tanks were a low priority."
Helm kept calling Ingram to find out the status of the replacement tanks.
"Harry told me they had some problems with the FAA, but that he would have a tank built by Friday," he said. "This call was made on Tuesday. I told Harry I would call on Friday and see how things were coming. When I called on Friday, Harry said the tank was not complete, but that the sheet metal had been cut and all that was lacking was to weld it together. We agreed again that this tank would be identical to the existing F21B tanks without the tabs.
A few days later he called to say the new tank was ready. I hired a driver to make the five-hour trip to LaGrange to pick up the tank. Instead of a new tank, I got a used tank with the tabs cut off. You could see where it had been drilled out of the wing of another F-22."
Frustrated, Helm posted his experiences on the Internet on the Taylorcraft Foundation Discussion Forum, on a message board titled "problems dealing with Harry Ingram and the factory".
"I knew there had to be other aircraft owners out there that were having similar problems and I didn't want them wasting their time or money too," said Helm.
"We had a fuel tank issue," Ingram concedes. "We had to redesign it. That took six months longer than I thought it would."
Ingram notes that he did not charge Helm for the replacement tank.
"It's not about the money," said Helm. "I just wish he had been up front with us from the beginning because then we could have approached the problem from a different angle. Instead he strung me along for three or four months."
My prewar vavle is a lot different than that one, mine has a pin soldered and the center body was machined to hit that pin and allow only a 90 degree rotation. tim
