Well I broke my tail spring and need replacement. I looked in A/S catalog and it shows one for the Taylorcraft BC-12D as 1 1/2 inch wide and 10 inches between holes. Well my old broken one is different. It is 1 1/4 wide and distance between holes is 12.5 inches. Humm, either the old one was home made or A/S is not selling the correct one. The distance from the tail post to the bolt for the tail spring in 6.5 inches foward of tail post. Is this correct? The old broken spring was 3 springs and so has the one A/S sells. I am confused. Now there had been a repair in the tail years ago due to rust and I wonder if the bolt hole for the tail spring was moved foward of the tail post then. Any help?
