Re: High CHT... again. All help/experiences wanted!
how long have you been using that engine Bill? is it new to you?
The lower edge of the rear curve, in the stamped rear baffle on the #1 cylinder side... was bent back and away from the fins to provide larger exit area. The baffle still lies flat against the rear vertical portion of the cylinder fins, but there is a significantly higher exit area.
