enamal paint
  • enamal paint
    What kind of primer can I use below the Polyfiber enamal paint? Tim
    Re: enamal paint
    Stits epoxy preferrably presuming this is on metal not fabric
      Re: enamal paint
      Exactly what Mike says... most of the "paint" problems can be traced back to people that know so much they have to mix systems.... paint is engineered to work best with a certain system, so start with one system and stick with it all the way through.
      JH
        Re: enamal paint
        I want to stay away from the 2 part epoxy's, that is why I went with the enamal. Will Zinc chromate work? or is there an enamal primer? Thanks Tim
          Re: enamal paint
          ask the manufacturer
            Re: enamal paint
            Tim, why do you want to stay away from 2part epoxy? It's by far the best primer out there!
            JH
              Re: enamal paint
              I only needed a pint to paint my cowl and some farings. I also dont have a proper place to spray the epoxy. If I was going to use a epoxy I would have used PPG auqapon which contains zinc and is chemical resistant. Tim
                Re: enamal paint
                Alodine the bare metal and then spray a chromate primer.
                  Re: enamal paint
                  Polyfiber's epoxy has chromate in it, and is also extremely chemical resistant.
                  JH
