Originally posted by crispy critter
View Post
Hi Kevin,
I have the tailpost vent (at the bottom rear). I've owned this plane in NY for 25 years (1982-2007).
Ironically the only period of time where I actually had longeron corrosion issues was during the period from 1984 to 1991 (approx) when I had mistakenly covered the hole with fabric back in 84. It was ok on 84 and bad in 91.
I believe that the vent hole is very helpful because of that experience.
I keep it clean and uncovered now.
My thinking about water and moisture is that you cannot stop it from getting but you must provide a way to get it out.
btw- I assume it will get into the top of the tailpost thru bolt holes and so on at the fin attach, that's just an assumption
