Can someone provide the dimentions of the "GUIDE - CONTROL WHEEL SHAFT - FIBRE"? Please! Or perhaps there is one for sale?
Guide - Control Wheel Shaft - Fibre
Re: Guide - Control Wheel Shaft - Fibre
Jim,
what material are you using? Is there a drawing or is it just a donut with an inside/outside diameter and thickness? I have never looked at mine but have wondered about the apparent slop in my control yoke...
Jack D
BC12D
I replaced mine with Phenolic and had the shafts rechromed, you might have to buff the hole a little but I remember the hole being just over .750 and I used a rotary flapper wheel with about 120 grit and a cordless drill to smooth out the for and aft motion. If you need the rubber u-channel, metro molded products sells it by the foot.
Look it up by product type and the dimentions that you need. They also have a real nice fuel tank grommet, GF22 that looks great and is not damaged by auto fuel.N29787
If someone would send me a sample or a drawing I can machine some from phenolic on my CNC router and supply them to the group for the cost of material and shipping.DJ Vegh
www.azchoppercam.com
www.aerialsphere.com
Mesa, AZ
I will see if I have any new ones left and will send you one if i doOriginally posted by N74DV View PostIf someone would send me a sample or a drawing I can machine some from phenolic on my CNC router and supply them to the group for the cost of material and shipping.
There are the STC SA666NW for a Teflon control yoke bushings, that I believe is a modern way of replace the old fiber bushings.-
The STC is at name of Mr. George Johnson of Puyallup, WA 98371.-
Best regards to all the Taylorcraft lovers.-
Miguel.-
