howdy all,does any have any info on the abw 850-6 thanks marc n43643
alaska bush wheel 850-6
Re: alaska bush wheel 850-6
I cant afford anything from Alaska Bush wheels and they dont like to get poked with anything, But I have McCreary 8.50's and love them. I am considering the Gar Aero tail wheel mod though, which is about 1/3 the cost of a bush tailwheel. TimN29787
Tim, are the McReary's very heavy? I looked thru some tire listings and found that larger tires are unfortunately quite a bit heavier than they ought to be. I want to put on 8.50's when my current 6.00's get worn out, and I couldn't seem to find any bigger tires that were lightweight. What do you figure the McCreary's cost you in higher weight?Originally posted by astjp2 View PostI cant afford anything from Alaska Bush wheels and they dont like to get poked with anything, But I have McCreary 8.50's and love them. I am considering the Gar Aero tail wheel mod though, which is about 1/3 the cost of a bush tailwheel. Tim
BillTaylorcraft : Making Better Aviators for 75 Years... and Counting
This is from Desser.......all 850-6's
The Goodyear at +/- 14 lbs.
The others are +/-
STA Airtrac 17
STA Superhawk 15.5
Michelin 15
850 x 6 Tube is about 3 lbs.
I bought new 4-ply AERO CLASSIC 600-6's and am going to sell them and put the Airtrac 800-6's on, as that seems to be the best compromise in my case. Anyone want some NEW 600-6 Aero Classics for cost?
Diameters on the Airtrac's:
AA1J2 - 800-6 Airtrac 19 inches
AA1K4 - 850-6 Airtrac 21.5 inchesMIKE CUSHWAY
1938 BF50 NC20407
1940 BC NC27599
TF#733
I never let the weight bother me, and I only lost a few MPH, so I think that the gain is worth more than the loss of useful. I only run about 10-12 psi so they are nice and cushy on landing. Any less pressure and you might roll a valve stem. Be aware if you run this low of pressure and you land on pavement, it will be different than landing with the smaller tires. They seem to stick to the runway more. TimN29787
