Left landing gear damaged ,both vertical tubes and axle aimed in the wrong direction. ? best way to fix? My present thought is to remove gear , straighten tubes as good as necessary to have axle in right position. Anybody done enough of this to have a good repair approach? John Wright
Left landing gear BC12d
Re: Left landing gear BC12d
The only good news is that folks seem to be asking for right LG, so you'll probably have little problem find a leftie.Originally posted by John Wright View PostLeft landing gear damaged ,both vertical tubes and axle aimed in the wrong direction. ? best way to fix? My present thought is to remove gear , straighten tubes as good as necessary to have axle in right position. Anybody done enough of this to have a good repair approach? John Wright
Straightening alone won't do it as the metal has been weakened.
See your favorite IA; he probably knows a welder he trusts - MikeHMike Horowitz
