Being another who desires at least one gyro attitude instrument in the panel, I purchased the venturi driven turn and bank kit offered by Aircraft Spruce and installed it, top and center, in N44305 last week while down for annual inspection. The AN 5280-1 T&B has 3 threaded ports on it - 1 on the top rear at an angle, 1 on the back and 1 on the bottom rear, none of which are labeled inlet or outlet. Included with the kit were 2 straight nylon 1/8" NPT with 1/4" straight barb fittings, plus a length of 1/4" tubing better suited as an undersized, very stiff hula-hoop. With the limited room between panel and gas tank, a straight fitting won't work on the back of the instrument. I consulted an avionics technician about which was in and which was out and whether the ports on the back and bottom were interchangeable (we had already determined that the combination of brass elbow with straight barb was several millimeters too long to add to the length of the instrument). That done, I removed the plug from the bottom port so it could be used, plugged the port on the back and hooked everything up, with a piece of gauze on the end of the inlet tube until a filter, not included in the kit, arrives. With the first turn away from runway heading on the way home, it was apparent that the inlet/outlet information was wrong since only the ball worked. That was confirmed with a call to the instrument overhaul shop; the technician also said the port on the back should be used, but couldn't say what the port on the bottom is for. It's hard to argue with the expert, but I do have two opinions and it sure looks like both ports empty the same chamber. I can't find any nylon fittings locally, but have found a one-piece brass elbow at NAPA that I hope will be short enough to clear the gas tank, unless one of you has already determined that the bottom port does work OK.
As an added bonus, the vertical card compass, sitting atop the panel above the T&B, which is in the hole formerly occupied by the tach, now is 30 or 40 degrees out of kilter. (?)
Any comments from those more knowledgeable will be welcomed. Thanks in advance!
Mike Volpp
Mike Volpp
