i want to put clear doors on my tcraft i remember coming across one that i liked that had what i was looking for it was a big pice of plexglass in it with just a small metal frame on it and i was wondering if there is an stc for it or do u think i can just get a field aproved ????
custom doors ??
Re: custom doors ??
Hey Tim,
I searched STCs and don't see one.
Go for an alteration.
If you are just replacing a portion of the lower door skin with plexi I don't believe it is a major alteration at all and therefore requires only an log book entry.
See FAR43, Appendix A(a)(1) where major alterations are defined.
Talk with your IA about it.
Maybe I am thinking too small and you want really big glass.
Dave.Last edited by Guest; 02-18-2007, 18:45.
Re: custom doors ??
ok i found it on an old website http://www.popularaviation.com/PhotoGallery/2999.jpg i want to make something like this but better
Re: custom doors ??
Tim, that is a prewar door.
The bottom is normally covered with fabric.
It has been replaced by plexi.
The door's shape is different than the bc12d metal door and the door frame is different too because it contours the steel tube inside of our door frames.
It's a real door, it fits the frame. Not one of those lyin doors like in a bc12d where the door is bigger than the frame for looks.
Its prewar plane, notice below the horizontal stabilizer and above the taail wheel there is something blue. That is a little surface that rotates up and down few degrees for trim, I beleive the proper name for it is a fletner. There is no trim tab on the elevator.
That trim device is on prewar planes.
Re: custom doors ??
I know that plane. It is in wasilla it belongs to charly center.
There is alot of doors like that here in alaska.Lance Wasilla AK
Re: custom doors ??
Yup thats the guy.Lance Wasilla AK
Re: custom doors ??
Originally posted by matsuthunder200 View PostI know that plane. It is in wasilla it belongs to charly center.
Tim, you'll have to try for a field approval and build them yourself... not that big of a deal...just make sure you get the approval BEFORE you start cutting your doors.
JHI'm so far behind, I think I'm ahead
