The rectangular aileron bellcrank inspection panels on the top of my wings run side to side, but most others I've seen run fore and aft, like the photos below. Does anyone know which orientation is correct? And how many attachment screw holes did those panels originally have? I think I remember seeing a factory drawing with eight screw holes...
Aileron bellcrank inspection panels
Re: Aileron bellcrank inspection panels
Nope rectangular and side to side....Taylorcraft Foundation, Inc
[email protected]
Originally posted by Joel @ IKV View PostThe rectangular aileron bellcrank inspection panels on the top of my wings run side to side, but most others I've seen run fore and aft, like the photos below. .Mike Horowitz
Yes Mike or "longways" ; Mrs. Feris went to the round standard plates on the F-19 as they did not have the die. they were "formed" to have the edge turned over on the edges like the glove compartment doors. The thoughts back then for better access were if you ahd to change the bellcrank, you could. AND the early ones had grease down in them with a cork on top.
The Model D used a lot of them......to access stuff.Taylorcraft Foundation, Inc
[email protected]
Originally posted by alwaysoar View Postand what backing do you use to screw into, and why not use round inspection covers (because they would flop around due to their location)?
Ed@BTV VT
TF 527
Hi Ed.
Originally posted by alwaysoar View PostAnd what dimensions, and what backing do you use to screw into, and why not use round inspection covers (because they would flop around due to their location)?
Ed@BTV VT
TF 527Mike Horowitz
Thanks Jim and Mike. Happy New Year to you both. My thought was to use regular round plastic rings and standard covers, but to drill through the cover and the ring into the spring clip in the cover and tighten down with screws or short AN#3 bolts so they wouldn't blow away in the turbulence on top of the wing. It would be easier to do than to make rectangular covers. Anybody see any problem with that idea?
Ed@BTV VT
TF527
Originally posted by alwaysoar View PostThanks Jim and Mike. Happy New Year to you both. My thought was to use regular round plastic rings and standard covers, but to drill through the cover and the ring into the spring clip in the cover and tighten down with screws or short AN#3 bolts so they wouldn't blow away in the turbulence on top of the wing. It would be easier to do than to make rectangular covers. Anybody see any problem with that idea?
Ed@BTV VT
TF527Mike Horowitz
The hole would be reinforced with the plastic ring and a fabric doily (is that the word?) My guess is that the cover would be very tight and secure to the fabric. My only reason for thinking of this approach is that it's a whole lot easier than constructing the rectangular cover with the backing for the screws and all. However, the hole would not be as large.
Ed
OK, found the drawings of the 4 1/2 inch x 7 1/2 inch inspection panel and its frame. Looks like eight screws.
"Side to side": Now I'm confused. On my plane, the 7 1/2 inch long side of the panels run parallel to the trailing edge of the wing, perpendicular to the ribs. Forrest, do I understand you to mean that the long side of the panel should instead run parallel to the ribs, as in the wing photos above?Joel Severinghaus
Des Moines, Iowa
TF# 657
Just realized I compressed those jpg thumbnails of the part drawings so far they're barely legible. PM me with an "outside the Forum" email address if you'd like me to email you the original, bigger, and readable files. The original files were 726 KB and 1.45 MB.Joel Severinghaus
Des Moines, Iowa
TF# 657
perpendicular to the ribs, longways to the trailing edge, what ever that is the correct wayTaylorcraft Foundation, Inc
[email protected]
That's one inspection panel I didn't put on Crispy,maybe I should have but I didn't want any holes on the top side of the wing that might let moisture run in on the spar.It makes it a little hard to get into the bell crank but I can still get to it to service it and/or safty the cables if I ever have to do so. I have another T-craft that I bought in November and it has the rectangle plate onto of the wing and the length of it runs in the direction of the wing,it also has small sqare plates on the bottom of the wing at each hinge point and on the aileron as well.....not sure why they did that yet but I have not removed any of them yet either. I'll try to get some pics before I cut the fabric off.Kevin Mays
