Re: bungee tool for rent?
DJ,
Replacing elastic shock absorbers on landing gear is specifically listed as a preventive maintenance item in FAR 43 Appendix A paragraph c(2).
If you look at FAR 43.3(g) you will see that a pilot is authorized do preventive maintenance on an aircraft he owns or operates (unless you operate under part 121, 127, 129,135).
So you can do this all yourself but you need to make a log entry per FAR 43.9
I recall the instructions that come with the tool tell you to make a log entry but don't explain all the legaleeze of why it's appropriate for you to do that.
Perhaps I should add that. What do you think?
Thanks, Dave.
Originally posted by N74DV
View Post
Thanks, Dave.
ops:
in our pack.
