1939 Model B control cables
  • 1939 Model B control cables
    Need some help here for originality: Pre-war Model B's should have had spliced or wire wrapped/soldered control cables. Anyone know which was the factory method? Also, were the different controls "color-coded" as in some early Pipers, and where (if they were)? What size 7x19 galvanized aircraft cable was used in the rudder and aileron systems? The cables I have are mixed sizes and mixed spliced - wire wrapped - nico-pressed. Would like to be able to return to the factory configuration. Thanks, in advance! Bob
    Re: 1939 Model B control cables
    My '41 had 5 tuck splices, and they were not tapered. They were also dipped or covered with some kind of substance, maybe Zink. Tom
      My 1940 BL (C) 65 still has two of the 5 tuck spliced cables. They are tapered neatly and are very attractive... little works of art. The other cables have been replaced with Nicopress sleeve terminals.
        My late 45 B still has some of the original spliced ends.
        We have a few chaps here in England (one is surprisingly young for such an old skill) who do cable splicing for some of the vintage / museum aircraft.
        The cost to the aircraft owner is very high, because of the time taken, etc.
          My 46 BC12D has all nicopress splices except one rudder cable has a hand made tucked splice! (Prewar leftovers?)
          The cables are all 1/8 inch galvanized.
          Bob Gustafson
          Bob Gustafson
          NC43913
          TF#565
            Andrew King (BaldEagle27 here on the forum) does museum quality cable splices. I have seen his work at Brodhead and it is spectacular!
            MIKE CUSHWAY
            1938 BF50 NC20407
            1940 BC NC27599
            TF#733
